Furnace/AC |
Post Reply | Page 123> |
Swift-Pod
Newbie Joined: 29 Dec 2011 Location: Presque Isle WI Online Status: Offline Posts: 18 |
Topic: Furnace/AC Posted: 18 Mar 2012 at 10:11am |
A bit of confusion this morning. Thanks to some very mild temps in Northern WI I was able to get our new pod close enough to the house to hook it up (20amp) and begin testing a few things before we start our month long Gulf Coast sojourn at the end of this month.
Started the furnace this morning and while it worked fine, the furnace setting on the thermostat also ran the AC at the same time. Maybe not the compressor but the fan was running. Is this normal? Couldn't get it to shut off without turning the furnace off. Thanks for your help. Duanne |
Duanne & Ann
2011 177 R-Pod 2007 Toyota Tacoma |
this_is_nascar
Senior Member Joined: 24 Jan 2010 Location: NJ Online Status: Offline Posts: 466 |
Posted: 19 Mar 2012 at 8:02am |
Unless they've changed the way the heater and A/C interact or maybe it's a difference between your model and mine, my heater controls and A/C controls are totally separate and the heater fans works with the heater and the A/C fan on the ceiling works with the A/C. They do not mix or share.
"Ray & Connie"
secretbard
Posted: 19 Mar 2012 at 8:19am |
Yeah, mine is the same way. The A/C has controls on the A/C and the furnace is controlled by the thermostat on the wall.
2010 Rpod 172 :)
2004 Chevy Trailblazer |
tpierce220
Senior Member Joined: 14 Jan 2011 Location: Oswego IL Online Status: Offline Posts: 281 |
Posted: 19 Mar 2012 at 9:50am |
Make sure that on the thermostat that the setting is not on AU, which will control the AC fan even if the furnace is running. You should see a Mode button. Cycle through it until it says off.
Tim
Posted: 19 Mar 2012 at 1:17pm |
They should operate separately even on the same thermostat, but I've heard of others with this problem. I think Tim's suggestion is the solution.
Goose
Posted: 19 Mar 2012 at 6:03pm |
Tim is right, make sure that the Fan is OFF and not on Auto. Did the same thing myself the first time. Goose
Swift-Pod
Posted: 20 Mar 2012 at 12:10pm |
Well, I guess I have it sorted out. Thanks to all for your help. Apparently the thermostat needs to be reset if when you turn on heat or air and they run simultaneously. This is accomplished by pushing both the mode button and the + button at the same time and holding them for a few seconds. Once reset it works fine. Funny a great number of things in this electronic world can be repaired this way. Resetting and turning things off and on seem to be the universal fix. Thanks again. Duanne
Duanne & Ann
Posted: 20 Mar 2012 at 1:37pm |
Works for Windows!
Guests
Guest Group |
Posted: 20 Mar 2012 at 4:24pm |
That's my solution for most everything at work!
If that doesn't work, I call the vendor.
thebegbie
Newbie Joined: 04 Jan 2012 Location: College Station Online Status: Offline Posts: 21 |
Posted: 20 Mar 2012 at 5:43pm |
Huh... I will have to try the reset: MODE + till it resets then... I had it on 78 degrees and furnace working great.. but then it got cold over night.. I had to press the mode to "off" - wait... then turn on furnace and it worked again. But I don't want to get up in the middle of the night because I'm cold.
It's a real thermostat right? Like the one at the house? It was like 65 in the camper - never turned on till I turned it off and back on... And then only for the one cycle again. |
'12 r-pod 177
2008 Toyota 4Runner 4x4 V6 Father of 3 Boy Scouts and yes, we cram 5 family members in our 177! When is the next camping trip? Because I'm ready for a vacation! |
