Furnace/AC |
Post Reply | Page <123 |
Goose
Topic: Furnace/AC Posted: 19 Mar 2012 at 6:03pm |
Tim is right, make sure that the Fan is OFF and not on Auto. Did the same thing myself the first time. Goose
Posted: 19 Mar 2012 at 1:17pm |
They should operate separately even on the same thermostat, but I've heard of others with this problem. I think Tim's suggestion is the solution.
tpierce220
Senior Member Joined: 14 Jan 2011 Location: Oswego IL Online Status: Offline Posts: 281 |
Posted: 19 Mar 2012 at 9:50am |
Make sure that on the thermostat that the setting is not on AU, which will control the AC fan even if the furnace is running. You should see a Mode button. Cycle through it until it says off.
Tim
secretbard
Senior Member Joined: 12 Apr 2011 Location: Budd Lake, NJ Online Status: Offline Posts: 195 |
Posted: 19 Mar 2012 at 8:19am |
Yeah, mine is the same way. The A/C has controls on the A/C and the furnace is controlled by the thermostat on the wall.
2010 Rpod 172 :)
2004 Chevy Trailblazer |
this_is_nascar
Senior Member Joined: 24 Jan 2010 Location: NJ Online Status: Offline Posts: 466 |
Posted: 19 Mar 2012 at 8:02am |
Unless they've changed the way the heater and A/C interact or maybe it's a difference between your model and mine, my heater controls and A/C controls are totally separate and the heater fans works with the heater and the A/C fan on the ceiling works with the A/C. They do not mix or share.
"Ray & Connie"
Swift-Pod
Newbie Joined: 29 Dec 2011 Location: Presque Isle WI Online Status: Offline Posts: 18 |
Posted: 18 Mar 2012 at 10:11am |
A bit of confusion this morning. Thanks to some very mild temps in Northern WI I was able to get our new pod close enough to the house to hook it up (20amp) and begin testing a few things before we start our month long Gulf Coast sojourn at the end of this month.
Started the furnace this morning and while it worked fine, the furnace setting on the thermostat also ran the AC at the same time. Maybe not the compressor but the fan was running. Is this normal? Couldn't get it to shut off without turning the furnace off. Thanks for your help. Duanne |
Duanne & Ann
2011 177 R-Pod 2007 Toyota Tacoma |
