battery disconnect |
Post Reply | Page 12> |
Robwid
Groupie Joined: 31 Oct 2011 Location: Oregon Online Status: Offline Posts: 67 |
Topic: battery disconnect Posted: 13 Feb 2012 at 10:17pm |
I'm just about to pick up my brand-spankin' new HRE 177. I went with the battery upgrade that includes 2 - 6V batteries. I'd like to put in a disconnect switch to prevent the batteries from draining during storage. Does anyone have a suggestion for a robust but simple switch or device to disconnect the batteries? Maybe I can simply disconnect the ground?
Thanks in advance for the advice. Rob |
Posted: 14 Feb 2012 at 5:53am |
I replaced the nuts on the battery with wingnuts. When not in use I remove the leads. I have to open the battery box, but it is simple and foolproof.
turncoat3
Newbie Joined: 02 Jan 2011 Location: Washngton, NC Online Status: Offline Posts: 37 |
Posted: 14 Feb 2012 at 9:39am |
Ben & Lorrie
2013 Surveyor 264 |
TIDALWAVE
Senior Member Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Posted: 14 Feb 2012 at 5:01pm |
I installed the same battery cutoff switch on my battery box. The copper posts on the switch extended fairly deep into my box. I didn't want the bare posts to touch the battery posts...so I installed the switch on the side of the box where the battery posts are farthest away. No accidental chance of a large short circuit! The red key stays in the battery switch when the switch is on. So if your TV-Pod wiring allows you to charge the battery from the TV while traveling the key is in the switch. I lucked out...two keys came with the switch. I keep one as a spare in a Pod drawer, just in case the traveling key gets removed and lost. |
TIDALWAVE
Footslogger03
Senior Member Joined: 21 Jul 2011 Location: Laramie, WY Online Status: Offline Posts: 362 |
Posted: 14 Feb 2012 at 5:04pm |
Livin' the Dream ...'Slogger
Footslogger03
Posted: 14 Feb 2012 at 5:08pm |
======================= This is almost identical to the one I bought - - but haven't installed yet. Waiting for the snow to melt ? Mine did not come with installation instructions though. My original inclination was to put the key switch in-line with the "+" terminal. Is everyone certain that the correct wire to use is the "-" terminal ... MJ |
Posted: 15 Feb 2012 at 8:14pm |
Coleman used to include a cut-off disconnect with their campers, don't know why all camper manufacturers don't do it, it is absolutely necessary. I installed a 30 amp blade fuse holder next to my battery box. When it is parked I pull the fuse and leave it on the counter.
dsmiths
Senior Member Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Posted: 15 Feb 2012 at 9:03pm |
Cost, eg, if it costs 9 dollars per unit and We produce x amount of units per year, x times 9, you get it.
Dane and Donna Smith
Posted: 16 Feb 2012 at 8:30pm |
yeah, but they could raise the cost to the end-user by $9. IMO a battery cutoff is just as essential as an LP detector.
Robwid
Posted: 17 Feb 2012 at 11:04pm |
