Axle Risers |
Post Reply | Page <1 23456> |
harleyguy1
Newbie Joined: 04 Dec 2010 Location: texas Online Status: Offline Posts: 38 |
Topic: Axle Risers Posted: 28 Sep 2011 at 6:20pm |
This sewer solution works well and will pump uphill. Sold by Camping World.
Marshal
2011 R-177 Longview, Tx |
Rabbit
Groupie Joined: 13 Sep 2011 Location: Wisconsin Online Status: Offline Posts: 70 |
Posted: 28 Sep 2011 at 11:36pm |
What are axle risers and what are they used for?
Rabbit |
Rabbit
Posted: 28 Sep 2011 at 11:38pm |
Does Forest River sell full covers for the different R Pods?
Posted: 29 Sep 2011 at 8:09am |
Axle risers are spacers that go between the axle and the frame, lifting the BODY of the camper about 4" higher. If you search for pictures of a "Hood River Edition", they all have them.. I think in the west, any place with Pods will have HRE's , or heck maybe that is all you have out there...? Forest River does sell covers, most think them a bit expensive and get one from Northern Tool or Cabela's, among other places that carry them. If you get or have an 18 series.. right now the only source is F.R. |
secretbard
Posted: 15 Feb 2012 at 9:31pm |
I think you guys may have convinced me to get the risers. If I am correct in your assessments, they will help me level out the Pod to where the hitch hooks up. Right now, I have a 3 1/4 inch drop on my hitch and the Pod is nose up... enough that it is not level when I am hanging out in the Pod while still hooked up to the Trailblazer. I was doing some measuring and even after getting the risers, I may still have to get a different hitch or a 5 1/4 inch drop hitch in order for the Pod to be more level when hitched. Why the hell is my Trailblazer so high? Anyone else have or have had a Trailblazer in the past encounter this conundrum? As I mentioned before, when my Pod is hitched the Pod is a bit low on the back which does bother me some and I did scrape the back stabilizers a couple of times on the drive down the bumpy backroads in VA last year. I know I mentioned before about the increase in height, but I guess I will have to deal with the increase in 4 inches and avoid those bridge underpasses that are lower.
Questions. Am I to believe that the height will increase 4 inches? How high will the whole Pod be with the risers (with the A/C)? I am not crazy about installing my risers myself, but the nearest Pod service center is quite a distance away from me. I figure that if I can grease my own bearings, I should be able to do the axle risers. What is the torque pounds one has to have on the bolts that hold the risers in place? I have a torque driver that will go as high as 180 pounds of torque. Another reason I am considering the axle risers is that there are a few places (namely a Duncan Donuts in Marshalls Creek, PA) where the dip in the parking lot entrance is so deep that I can see scrape marks in the macadam that were made by many other vehicles passing over that spot. I just know that I would bottom out there and in a few other spots. Thanks again to those on this forum who have posted information on this and are willing to answer my questions. I love you guys.
2010 Rpod 172 :)
2004 Chevy Trailblazer |
secretbard
Posted: 15 Feb 2012 at 9:47pm |
I am actually thinking about keeping the same hitch which is a 3 1/4 inch drop because it may actually work with the 4 inch axle risers. In other words, I'll see what the difference is after installing the axle risers. It might just level out without the lower ball hitch.
In addition to the other questions in the above post, can anyone point me to the post with the picture of the different Pods side-by-side (one with the risers and one without). I know there is a thread here that shows the step-by-step with pictures of how to install the risers. Can you guys point me to that thread. Thanks. Edit: I just remeasured and it looks like with the 4" axle risers, my Pod will level up almost to within one inch of my Trailblazer hooked up with the 3 1/4" drop on my hitch that I have now.
2010 Rpod 172 :)
Posted: 16 Feb 2012 at 8:46pm |
I would wait to see how it levels out in the real world. In the end you want the tongue either level or slightly nose-down. I think the instructions say how much to torque everything down, but its been a while so I don't remember off the top of my head.
TIDALWAVE
Posted: 01 Mar 2012 at 8:22pm |
Determine if you have a Dexter or Lippert Axle before ordering risers from Forest River.
Your manual should be able to tell you which you have. |
TIDALWAVE
secretbard
Posted: 01 Mar 2012 at 11:04pm |
So, I couldn't find anything in the manual that indicated whether it is a Dexter or Lippert axle. Which is it? When I called Forest River, the nice lady took down the last four numbers of my VIN number, so I assume she gave me the right ones. The riser they sent me is the Lippert. Doesn't anyone have any insight as to if I received the right one. I briefly looked under my pod and it looks to be about right. Thanks for the info.
2010 Rpod 172 :)
secretbard
Posted: 02 Mar 2012 at 6:00pm |
It's supposed to be warm tomorrow (53 degrees), so I plan on doing the axle risers and greasing the bearings in the morning. Unfortunately, I won't be able to dewinterize the pod as the temperature is still going to be in the 20s for the next couple of weeks. I peered under the Pod to look at the configuration of the axle and bolts and it seems to match up to the Lippert one they sent me and the picture of the DIY thread. I'll let you know if I have any problems. I'm hoping that this will be pretty straight-forward and not too time-consuming.
2010 Rpod 172 :)
