Axle Risers |
Post Reply | Page <1234 6> |
secretbard
Senior Member Joined: 12 Apr 2011 Location: Budd Lake, NJ Online Status: Offline Posts: 195 |
Topic: Axle Risers Posted: 03 Mar 2012 at 6:34pm |
Well guys, I installed my axle risers and what a difference it makes. I did have a scary moment on installing the second axle riser. When I took the nuts and bolts out of the last one, it slid sideways and I had to pull it to one side so that the holes would match up. In doing so, the axle slipped off the jack and hit the ground. Hopefully that didn't screw anything up, and luckily my leg wasn't under there when it happened. After getting the holes matched up, I finished the job while also greasing the bearings after each one done. It looks really good and really raises the pod off the ground. An even more amazing thing... when I hooked up the pod to the hitch, after the back of the truck dipped about 2 inches, I put a level on the pod and it was perfectly level. No more having the pod dip in the back. Now I can leave the pod hooked up if I'm on the road and want to take a nap in a parking lot. Oh, and I know I won't have any problem now with any of the dips in the entrance to many parking lots and the dips in the dirt roads in the VA campsites. So I am very happy to say the least. It was quite a job though... took me a little longer than it probably should have.
I would like to know though, how high is my pod with the axle risers (I have the air conditioner on the roof)? Have any of you guys considered getting larger tires? How large can you go with your tires? I will probably go to the 15" tires or larger when these 14" tires wear out. A final note: I love this forum. I would have never attempted this had it not been for the DIY thread.
2010 Rpod 172 :)
2004 Chevy Trailblazer |
UPWILD
Newbie Joined: 20 Jan 2012 Location: UP,MI Online Status: Offline Posts: 16 |
Posted: 03 Mar 2012 at 6:30pm |
The comments on axle risers are very interesting. Never gave it thought before. Anyone put them on 151? UPWILD
UPWILD
TIDALWAVE
Senior Member Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Posted: 03 Mar 2012 at 11:04am |
I mis-spoke...please read 'dsmiths' thread further on. There is a label on the right side of the axle which gives the manufacturers name. It has been awhile since I installed my risers. I rechecked my manual...nothing said about the axle. FR may install either axle so no use in printing the axle in the manual. So if your Pod is new...the label should be quite easy to read.
TIDALWAVE
Snowbound
Senior Member Joined: 17 Apr 2011 Location: Edmonton, AB Online Status: Offline Posts: 270 |
Posted: 02 Mar 2012 at 11:19pm |
We camped from Alberta to Ontario and then down to Arizona and back then Tom had the risers installed at our RV dealer. There were just too many gas stations and parking lot entrances where our stabilizers dragged or even dug in. We had no trouble in campgrounds or dumping but getting stuck halfway out of a parking lot with traffic heading towards us convinced him he was not willing to drag the pod around all next summer having the same fears. I believe they switched the hitch height by truning it upside down.
Tom and Bette
in our 177 "The Gastropod" |
dsmiths
Senior Member Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Posted: 02 Mar 2012 at 9:43pm |
As you might have seen from an earlier post, FR sent me the wrong riser kit, they billed it as a dexter, but sent me a lippert, brandy in fr parts got it fixed super fast, look on the right side of the axle there should be a label, also where the factory frame bolts to the axle the dexter bolt holes are 8 iches on center the lippert are 8 and 3/4. good luck, make sure the frame is supported well, make sure someone is near, dont get under the pod with the tire offwith less than two types of support, also lay the tire flat and push it under the middle of the axle, if all else fails it will drop and hit the rim possibly saving you. good luck and report back.
Dane and Donna Smith
secretbard
Posted: 02 Mar 2012 at 6:00pm |
It's supposed to be warm tomorrow (53 degrees), so I plan on doing the axle risers and greasing the bearings in the morning. Unfortunately, I won't be able to dewinterize the pod as the temperature is still going to be in the 20s for the next couple of weeks. I peered under the Pod to look at the configuration of the axle and bolts and it seems to match up to the Lippert one they sent me and the picture of the DIY thread. I'll let you know if I have any problems. I'm hoping that this will be pretty straight-forward and not too time-consuming.
2010 Rpod 172 :)
secretbard
Posted: 01 Mar 2012 at 11:04pm |
So, I couldn't find anything in the manual that indicated whether it is a Dexter or Lippert axle. Which is it? When I called Forest River, the nice lady took down the last four numbers of my VIN number, so I assume she gave me the right ones. The riser they sent me is the Lippert. Doesn't anyone have any insight as to if I received the right one. I briefly looked under my pod and it looks to be about right. Thanks for the info.
2010 Rpod 172 :)
TIDALWAVE
Posted: 01 Mar 2012 at 8:22pm |
Determine if you have a Dexter or Lippert Axle before ordering risers from Forest River.
Your manual should be able to tell you which you have. |
TIDALWAVE
Posted: 16 Feb 2012 at 8:46pm |
I would wait to see how it levels out in the real world. In the end you want the tongue either level or slightly nose-down. I think the instructions say how much to torque everything down, but its been a while so I don't remember off the top of my head.
secretbard
Posted: 15 Feb 2012 at 9:47pm |
I am actually thinking about keeping the same hitch which is a 3 1/4 inch drop because it may actually work with the 4 inch axle risers. In other words, I'll see what the difference is after installing the axle risers. It might just level out without the lower ball hitch.
In addition to the other questions in the above post, can anyone point me to the post with the picture of the different Pods side-by-side (one with the risers and one without). I know there is a thread here that shows the step-by-step with pictures of how to install the risers. Can you guys point me to that thread. Thanks. Edit: I just remeasured and it looks like with the 4" axle risers, my Pod will level up almost to within one inch of my Trailblazer hooked up with the 3 1/4" drop on my hitch that I have now.
2010 Rpod 172 :)
