Genny for RPOD |
Backstraps_RPOD
Newbie Joined: 19 Jul 2011 Location: IL Online Status: Offline Posts: 2 |
Topic: Genny for RPOD Posted: 02 Aug 2011 at 5:46pm |
Hi all, awaiting my 182 from Forest River and had a question about using a Genny with it..
would a Honda 2000I work with it or to small for the ac unit.. its 120v but dont think it would power the ac unit.. Trying not to have to buy a new genny... lot of places we go do not have RV parks to plug into... thanks for your time
Backstrap
Guests
Guest Group |
Posted: 02 Aug 2011 at 7:09pm |
Welcome to our group and congratulations on your new Pod!
The genset you mention is a fine unit and quite popular. However, it is just a tad too small without making a modification to the air conditioner (a "hard start capacitor"). If you do a search on the subject, you'll likely find the info. If you have trouble finding this, give a shout and I'll find it and point you to it. I'll offer this caveat: Making this modification may void the warranty on your A/C unit.
psaman
Senior Member Joined: 26 Jun 2010 Location: Corpus Christi Online Status: Offline Posts: 231 |
Posted: 02 Aug 2011 at 7:41pm |
Welcome Backstraps_RPOD !!
2011 R-177 "Sponge-Pod"
2011 F-150 XLT "Texas Edition" |
Posted: 02 Aug 2011 at 9:10pm |
Welcome. A hard-start capacitor is very cheap and not hard to install, so its worth a try. Just understand it may not solve the problem. Worth a try though.
Guests
Guest Group |
Posted: 03 Aug 2011 at 7:09am |
I found one of the posts here:
I seem to recall one or two have tried this - perhaps they will see your question and respond. I do not use a genset, so I have no personal experience. I'll echo what Techntrek says...I am not certain it if will work.
Posted: 03 Aug 2011 at 10:26am |
2000 watts is on the edge. However, the A/C units used on the 'pods are higher efficiency than older A/Cs. My running watts with the fan on low is 1000, where the A/C on my popup was around 1600. Its the startup surge that will make or break the deal. It wouldn't hurt to try it on a hot day before you get the capacitor.
Backstraps_RPOD
Posted: 03 Aug 2011 at 10:29am |
Thanks if its to much of a load it should only pop the breaker on genny... I hope
Backstrap
cane2
Groupie Joined: 06 Dec 2009 Online Status: Offline Posts: 92 |
Posted: 03 Aug 2011 at 10:33am |
Here is another benefit to a hard start cap it will also run off of a 20 amp circuit at your home. There is a kit made to extend run time you can go to 3 gallon or 6 gallon or 12 gas tank if you want to i think they are called extended run tanks. I use a 3 gallon one and it runs all nite then some. I can run my 2000 on eco mode when using my air I have a 11,000 btu air but have heard they will also run a 13,500 btu also on eco mode.
