How do you grease your wheel bearings? |
Outbound
Topic: How do you grease your wheel bearings? Posted: 23 May 2011 at 8:35pm |
etrailer.com has some excellent videos on how to inspect, remove and repack your bearings (link)
Outbound
Posted: 23 May 2011 at 6:36pm |
I follow the manufacturers guidelines. Every spring, I remove the wheels, remove and inspect the bearings, clean and repack the bearings, adjust the breaks and reassemble.
I do not recommend using the zerk fittings to squirt in extra grease. If grease gets past the rear seal, it will go directly on the brakes.
secretbard
Posted: 23 May 2011 at 5:39pm |
Sorry guys, but I'm still a noobie to trailers or towing.
So how do you do it? Do you have to remove the whole wheel to get to the bearings?
2010 Rpod 172 :)
2004 Chevy Trailblazer |
