Pawpod
Topic: RPod 177 walkthrough video Posted: 06 May 2011 at 1:32pm |
Video'd our walkthrough with our dealer. Not Hollywood quality but he go's through everything including winterizing.
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
For some reason my first try had no audio.  breaking it up into 6 parts worked though
Ready to pod around!
Posted: 06 May 2011 at 2:39pm |
Moved to the maintenance section, I think its more appropriate there. Thanks for sharing the video, I'll check it out at home later (Youtube is blocked where I work).
jayber
Posted: 06 May 2011 at 5:39pm |
This is great, since we had our pod delivered we didn't really get a walk thru.
Jay
2010 Honda Odyssey
RP 171 aka PodInn
Pawpod
Posted: 06 May 2011 at 6:04pm |
Thank you techntrek. I wasn't sure where to post it. And I hope it helps jayber.
Hodge-PODge
Posted: 07 May 2011 at 11:51pm |
Pawpod, thanks for posting the walkthrough videos. I watched them all. Did I hear right -- that the inverter (is that what's it's called?) takes automotive fuses -- he said 2 40-amp fuses and the rest were 15-amp fuses? I was surprised because I don't think my pop-up took anything more than a 30-amp fuse.
In any case, can someone tell me WHICH kind of auto fuses the guy was talking about--one kind has a square end, and another has more pointed ends, right? When I was in WalMart today I wasn't sure which ones to buy for spares, although I almost took a chance and bought the square-ended ones.
Also, I know I don't have to worry about winterizing until the fall. But when he showed the water heater bypass valve UNDER the bed, I got such a feeling of dread. I can't lift that dang awkward mattress as it is -- how in the heck can I ever get to that darn valve? When the time comes, I'm afraid Miss Independent Me is going to have to ask SOMEBODY for some help after all!
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
Pawpod
Posted: 08 May 2011 at 7:59am |
Didn't take a close look but I assume it's like this -
Hodge-PODge
Posted: 08 May 2011 at 11:46am |
Thanks, that was my guess.
2011 Mercedes ML350
Snowbound
Posted: 08 May 2011 at 3:20pm |
Thanks so much Pawpod,
I took lots of notes but didn't write down everything and have forgotten lots of it already.
Your video has reminded me and I expect we will be reviewing it a few more times!
B
Tom and Bette
in our 177 "The Gastropod"
Posted: 08 May 2011 at 8:58pm |
Yes, the converter (inverter goes 12 V to 120 V AC, converter goes 120 V to 12 V) uses automotive blade-style fuses on the 12 volt circuits - lights, water pump, etc. It wouldn't hurt to get an assortment and keep them with you just in case.
