  New Posts New Posts RSS Feed: POLL: Leveling
Topic ClosedPOLL: Leveling
Poll Question: What do you use to level your trailer?
11 [26.83%]
21 [51.22%]
8 [19.51%]
0 [0.00%]
1 [2.44%]
This topic is closed, no new votes accepted
Hodge-PODge View Drop Down
Direct Link To This Post Topic: POLL: Leveling
    Posted: 04 May 2011 at 3:13pm
Would it be a good idea to put a plastic level pad under the BAL when setting up anyway -- or not?  If you're going to camp for a few days, sometimes it does rain -- as we all know.
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
TIDALWAVE View Drop Down
Direct Link To This Post Posted: 04 May 2011 at 3:08pm
I love using my BAL Leveler...but be warned that if the Leveler is set onto soft soil, the weight of the POD may cause the Leveler to sink slightly into the ground.  When you go to lower the BAL, it may be difficult or impossible to pull the leveler out away from the tire.  You won't be able to just slip the Leveler out from the tire. The Leveler arms fore and aft then will not allow you to pull away from the leveler. In this situation, I found that I had to jack the tire slightly higher and slip a plastic level pad under the tire. This keeps some weight off the BAL so that I can then slip the BAL out from the tire.  I then  drive the POD off of the pad.
If the camping surface is solid, the BAL is quite easy to remove.
TIDALWAVE
drdrew View Drop Down
Direct Link To This Post Posted: 04 May 2011 at 2:39pm
i think mine was about 60 bux.  love it.
172T
Direct Link To This Post Posted: 04 May 2011 at 2:31pm
About the BAL, I can't believe in all the years I've camped (from tents to pop-ups to fifth wheels to R-Pod) that I never ever knew about that little doo-hickey!  The video was great.  How much do those thing-a-ma-jiggies cost?
2011 Mercedes ML350
psaman View Drop Down
Direct Link To This Post Posted: 04 May 2011 at 2:10pm
I think the company's name is BAL; but it is a leveling device that fits under the low side tire and yo crank it up to level. This link shows one.
http://www.youtube.com/watch?v=GuxdJyMU2RY
2011 R-177 "Sponge-Pod"
Direct Link To This Post Posted: 04 May 2011 at 2:05pm
What is a BAL?
2011 Mercedes ML350
Butterfly_Lee View Drop Down
Direct Link To This Post Posted: 04 May 2011 at 1:41pm
I use a BAL and it stores in the pass though (I have a 172)...I also carry a 6X6x18(?I'll have to measure to be sure) block of wood that I put in the tongue.  Saves on cranking up and down.
LeeClap
Still a work in progress, lots of pictures.
http://podterfly.blogspot.com/
Direct Link To This Post Posted: 15 Mar 2011 at 5:09pm
the BAL is a nice unit, i have one and use it.  stowing it is the PITA though.
172T
Direct Link To This Post Posted: 15 Mar 2011 at 4:55pm
Lynx, but I still carry the 2 boards I used for years.  Some times I'll use them under the corner jacks if they are especially high off the ground or in the mud/sand.
Direct Link To This Post Posted: 15 Mar 2011 at 4:48pm
Lynx for me.  They're light, easy to store and clean.
