Trailer Tire Sources |
woxofcavu ![]() Newbie ![]() ![]() Joined: 21 Oct 2021 Location: PNW Online Status: Offline Posts: 2 |
![]() ![]() ![]() ![]() Posted: 06 May 2025 at 1:29pm |
I have an R-pod 180 and it's that time to buy new tires. Two issues: 1. ETrailer, the only company I could find that has these in stock, will not guarantee a minimum age of their tires. Theoretically, they can send me two, six year old tires for $621. Since these are shipped, I cannot check the date code before buying like I do on my car tires. Anybody have a good source for tires meeting the below specs (in stock) and can guarantee a minimum tire age? ST235/75R15 Max load 2910 lbs @65 psi Speed Rating L 75mph Load Range D Thank You |
tektonik
James07 ![]() Newbie ![]() Joined: 19 Feb 2020 Location: Sacramento Online Status: Offline Posts: 27 |
I went with Carlisle Radial Trail HD, load range D. However, they don't come in ST235. I went with ST225 on same rims and they are fine. A number of friends did the same size change with Goodyear Endurance.
The first tire dealer would not guarantee a fresh tire and would not return it to warehouse. I went to another dealer and they agreed to send back a tire if over a year old. The pair of tires turned out to be 6 months old. If you want to stay with 235, you might have to go with LT235 from Sams or Costco. They are big enough to demand fresh tires from warehouse.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3360 |
Where I live I purchased from Discount Tire, which by the way, guarantees fresh tires. I , like James, went with Carlisle Radial Trail HD, load range "D" tires. They are equal or better, plus their warranty is 2x longer than goodyears.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 404 |
When we replaced the tires on our Rpod, we went with LT tires in the 235 size, Falken Wild Peak to be exact. There's a lot of discussion on whether LTs should be used on campers. We had our tires replaced at a tire shop that serviced most of the RV shops in town.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
My 2015 model 178 came with LT235 and was specified on name plate. First replacement was a LT235 Toyo Open Country A/T. These Toyo's were great tires. Performed well on 7,000 mile round trip CA to AK.
After aging out, after six years and plenty of remaining tread, I really wrestled with replacing with LT or ST. Decided to give ST a try with because of the higher load range D.
Thanks for the info gents! Will pursue these leads...
tektonik
