  New Posts New Posts RSS Feed: Battery Update
Battery Update
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Topic: Battery Update
    Posted: 02 Feb 2024 at 3:39pm
It has now been three months since these 12v batteries received a 24 hour 2 amp trickle charge.  The Interstate reads 12.60 v and the Trojan T-1275 is still at 12.69 v.  They remain sitting directly on the concrete floor in an unheated garage.  Temperature in the garage is 36 degrees.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2024 at 8:32pm
Four months since each battery received a 24 hour 2 amp trickle charge.  Interstate reads 12.58 volts, Trojan T-1275 has actually risen since last month and reads 12.71v.  That is a mystery to me, but used two different voltmeters and got the same result.  Maybe due to the ambient temp in the garage is 38 degrees yet the cement floor they sit on is probably the same temp as it was a month ago.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2024 at 6:53pm
Five month update: Interstate is at 12.49 volts, Trojan T-1275 is at 12.68 volts.  A few weeks ago they were each given a load test.  Interstate is showing its age as it only put out 30% of full whereas the Trojan was at 100%.  Will continue to use the Interstate as it is still good for 2 days while boondocking when night temps are in the 40's with the furnace running a lot.  The Trojan is good for 5+ days under the same conditions.  Interstate is now officially 14 years old, the Trojan will turn 4 in August.
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 6:54pm
Excellent info! Really interesting on the Trojan readings.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 8:56pm
I hope you have included the Trojan battery in your will because it appears it will out live you!
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Triumph T120
