Furnace help |
Post Reply | Page 123 4> |
Maddoxjprice
Newbie Joined: 03 Nov 2021 Location: Dallas, TX Online Status: Offline Posts: 19 |
Topic: Furnace help Posted: 31 Jan 2022 at 7:10pm |
I just bought a 2012 177. I haven't had to use the furnace but it's going to get below 10 degrees on Thursday and I'm worried my space heater won't do the job anymore. I just tried it out and, as I can see, the air blows out from under the bed. But the metal plate that covers it is missing! Is that a big deal? Should I not use it unless I have that cover? Also, the a/c from up above doesn't turn off, why is that? Help, I'm new at this!
Maddox Price
Winterpod
Newbie Joined: 17 Oct 2015 Location: Ketchum Online Status: Offline Posts: 34 |
Post Options Quote Reply Posted: 31 Jan 2022 at 7:48pm |
Make sure the thermostat is set on AU
Go to the fan setting then use + or - buttons Should show hi,low,au on screen Hope this helps
Winter pod
2013 R-Pod 178 2007 Silverato 1500 LT. Trek Stash 8 29er hard tail Old Town Kayak |
Post Options Quote Reply Posted: 31 Jan 2022 at 8:06pm |
In addition to the above it is not a big deal that the metal cover plate is missing. It will still run normal. Just be careful to keep everything a good distance away - nothing under the bed - for safety sake. There have been quite a few here who have constructed a diverter so that the heat exiting the furnace gets out to the main area better, also freeing up a good half of the space under the bed so you can utilize it for storage, even with the furnace running. It is a nice modification.
Post Options Quote Reply Posted: 31 Jan 2022 at 9:45pm |
Nothing to add about the furnace but at 10 degrees you almost certainly need to drain and or winterize your plumbing. TT
FJ Cruiser |
Post Options Quote Reply Posted: 01 Feb 2022 at 6:23am |
I would have thought that a 2012 would not have the integrated a/c and furnace thermostat like the later models do. My 2015 had a nice simple tstat dedicated to the furnace only. There is no reason firvhe roof a/c fan to be running when you're using the furnace.
As for the cover, you should replace it. It is designed to minimize the amount of hot outlet air that gets immediately pulled back throygh the inlet into the furnace. That's because the inlet about outlet ave right next to each other. If you don't have that the furnace will be inefficient at best and could overheat at worst. OTOH a baffle redirecting the air out firm under the bed is not needed. If it was then it would have been put there at the factory. The gap between the floor and the bed is huge and allows for plenty of air convection into the room. Just don't fill it up under there with stuff and you will be fine. |
Maddoxjprice
Post Options Quote Reply Posted: 01 Feb 2022 at 7:27am |
Thanks! Any idea on where to find one of those covers?
Maddox Price
JR
Senior Member Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 345 |
Post Options Quote Reply Posted: 01 Feb 2022 at 7:42am |
I would start with the manufacture, I have a 2019 Rpod and the manufacture is Suburban model # NT-20SEQ but you will have to check your furnace to make sure of the manufacture and model number. If it is in fact a Suburban their phone number is 423-775-2131 according my manual. Hope this helps.
Jay
179/2019 |
Post Options Quote Reply Posted: 01 Feb 2022 at 10:00am |
I had an early 80s camper which had the same furnace (except pilot ignition not direct spark) and it had the same cover. Suburban had been making that furnace forever. So you might try an RV shop in your area and see if they have an old one laying around.
Post Options Quote Reply Posted: 01 Feb 2022 at 10:30am |
Edit: Just because the factory did not include it does not mean that it isn't needed. There are lots of modifications I have made that the factory did not include because it made things easier or better (in my opinion). Forest River is not necessarily going to put some items on because they want to keep the cost low. It just means that we get to do the modifications if we want to improve things.
Post Options Quote Reply Posted: 01 Feb 2022 at 12:43pm |
Agree, I have seen the same Suburban furnace on a variety of different TT's so the cover plate should be readily available from Suburban.
