  New Posts New Posts RSS Feed: Relocate Microwave
Relocate Microwave
Hardwear Hank View Drop Down
Post Options Post Options   Quote Hardwear Hank Quote  Post ReplyReply Direct Link To This Post Topic: Relocate Microwave
    Posted: 19 Jan 2022 at 6:49am
Under the jack knife sofa their was a backer panel about 14” x 60” I pulled it out and used it. It really served no purpose where it was.
Hardwear Hank
2021-192
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2022 at 10:22pm
Where did you find the wood that matches the original wood?
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 9:46am
I would be very concerned about the cabinet strength too. I had to reinforce my overhead shelves on my 195 last year. They were separating. They are held up with small screws that can easily pull out with a little weight on them, going over bumps. Not saying it can't be done, but it must be reinforced in my opinion as well. My 195 has the low micro also, but for the limited number of times I use it, mmmfff
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Olddawgsrule View Drop Down
Post Options Post Options   Quote Olddawgsrule Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 7:35am
FR not does mount anything heavy from the walls. When I replaced the upper cabinet I learned why. I replaced because it was falling off and poorly constructed.
Reinforcing the sides is very important, I did the same just for the cabinet (not near the weight you will have). Honestly, I would totally rebuild the cabinet on the right and add a shelf under the micro to support it. I would not rely back the micro hanging bracket alone.. not in a camper! I would also reinforce the back wall. With all this done, I would think it would actually stay in place.
JMHO
P.S. We took delivery without a microwave. We rarely use the one at home, never have while traveling and preferred the space for additional storage, but that was us.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 5:51am
Be sure you maintain the required safety clearances if you move that microwave. You might want to look at getting a low profile over the range microwave with integrated ventilation. That would be designed for the heat from the stove top. I doubt the standard rpod microwave is.
Post Options Post Options   Quote Hardwear Hank Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 5:36am
Here goes, I now have 2 useable drawers and a microwave I do not have to pray to!
These are just renderings, actual project not completed yet. With the weight of the microwave up top I had to add reinforcement walls to both sides of the upper cabinet. And make the right upper cabinet smaller.
Hardwear Hank
2021-192
TheBum View Drop Down
Post Options Post Options   Quote TheBum Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2021 at 12:18pm
Yeah, you just about need a chair or stool. Not the best decision IMO. My 196 is the same way.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Post Options Post Options   Quote Hardwear Hank Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 2:17pm
Thanks for the tips. My plan would be to run the power behind the refrigerator. Getting down on the floor
to put something in the microwave is crazy.
Hardwear Hank
2021-192
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 1:06pm
There is quite a bit of difference between the 192 and the 179. The 179 has the wiring for the microwave. The 192 would not have the wiring to plug in the convection/microwave. Another consideration is the depth of the cabinets. You would need to measure to ensure that there is not only enough height for the microwave, but enough depth. I am guessing that you already checked the width. The final consideration is, as you asked, weight. While it is possible, and even probable that the weight could be supported, the cabinets were not built for that purpose. I suppose you could contact the factory to ask. However, that is likely to get you a statement that if you do so, you will void your warranty.
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 7:20am
I have a 2019 179 and the microwave came located in the trailer from the factory in the cabinet above the fridge in the slide out.  One thing I have noticed is that there is plenty of room with no obstructions between any interior cabinet walls or shelves and the microwave, like a minimum of 2+ inches with grill openings above and below the front of the unit.  This would allow for a lot of ventilation and a reduction of heat build up in the cabinet.  Something to be aware of when making your plans.  Hope this helps.
Jay
179/2019
