Sagging floor and outriggers |
Post Reply | Page 123 4> |
Masternav
Newbie Joined: 14 Jun 2021 Location: Montana Online Status: Offline Posts: 5 |
Topic: Sagging floor and outriggers Posted: 11 Aug 2022 at 10:35pm |
Thank you for the information. FWIW, the 2021 model change did not solve the floor sagging problem. The new outriggers are too flimsy and spaced too far apart. The support toward the front of the slide (just in front of the axle) broke the spot weld and the support toward the back of the slide (behind the axle bent out of shape. The end result is the same: Outer edge wall and floor sags, the slide drags on the floor inside, the fender slants down, and the slider doesn't evenly meet the weather seals. I've currently got the outside floor squared up with a jack, with a jack stand supporting the axle. If I can obtain these in short order, I hope to be able to keep it that way, with supports every foot or so. Thanks again! |
2021 R-Pod 190, Towed by 2013 Honda Pilot Touring
Masternav
Post Options Quote Reply Posted: 11 Aug 2022 at 10:33pm |
Masternav
Post Options Quote Reply Posted: 11 Aug 2022 at 10:31pm |
Can't delete
Post Options Quote Reply Posted: 24 Mar 2022 at 10:14am |
+1
Corrosion would be the main concern. The PVC would be pretty much corrosion proof. Steel would rust, and even aluminum (unless anodized) would corrode. PVC has reasonable resistance to compression too.
Post Options Quote Reply Posted: 24 Mar 2022 at 5:10am |
should work fine but the PV trim suggested above is probably better long term bc it won't rust.
MitchReef
Newbie Joined: 15 Sep 2020 Location: Oviedo, FL Online Status: Offline Posts: 27 |
Post Options Quote Reply Posted: 23 Mar 2022 at 9:04pm |
What does everyone think of getting a piece of 1/4 thick steel and put it under the floor in the gap over outriggers? Further support at the same time.
Mitch and Laurie Carter....
Still rolling.... |
Post Options Quote Reply Posted: 15 Mar 2022 at 7:11pm |
Well, fabricators aren't engineers and vice versa.
I can tell you with certainty that notching that outrigger would be fine. The purpose of the outrigger is to carry a moment (think torque) load back to the rpod frame. That moment load starts at zero out at the end and increases to it's max where the outigger attached to the frame rail. It's exactly like when you drive a nail a little into a piece of wood and then push sideways on it. The nail will bend where it enters the wood every time, never out at the end. I'd be a lot more concerned that the outrigger would pull out of the thin wall frame rail than I would that that little notch would cause a problem. |
Post Options Quote Reply Posted: 15 Mar 2022 at 6:35pm |
I emailed Innovative Machine, and they suggested not cutting the rail or the outrigger, but shimming it thusly:
I would suggest the following: 1) purchase some 1/4 PVC board at Home Depot and cut strips to be siliconed on the top of the outriggers to fill the gap with the wood floor 2) Do not cut the rail or notch the outrigger - the gap is approx 1/8 in the alum rail - I would suggest finding some washers and adding 2 on each bolt to fill that gap
Post Options Quote Reply Posted: 13 Mar 2022 at 12:11pm |
I would notch the outrigger. This won't weaken it significantly, the bending moment (torque) on the outrigger increases toward where it attaches to the frame and is very small out at it's end. As LA says the less you modify/make holes in the trailer itself the better.
sjesse
Newbie Joined: 04 Jan 2022 Online Status: Offline Posts: 5 |
Post Options Quote Reply Posted: 12 Mar 2022 at 7:14pm |
I think either way is ok as long as the weight of the outer 1 1/2" of the wall is on the outrigger since the floor underneath is only 1/8 luan plywood and would not be able to hold much weight.
So we want the outrigger on the 1 1/2" aluminum floor framing, not mainly on the floor. I opted to put the outrigger over the aluminum channel with a 1/8"x1/2" aluminum shim in the open area of the channel with caulking to seal the 2 screws we put up threw the wall, my thinking was it would help distribute the weight over a little larger area of the wall. Like I said earlier I did put some 1/4" thick PVC on top of the outriggers for a little more support. I cut them from a piece of 1/4"x2'x4' Vernada PVC trim board I got from Home Depot. Our Rpod 190 which had no outriggers originally was sagging 1" ( tire was hitting fender) and after jacking the walls back up over a 2 week with 4 scissor jacks and 4x4 under the walls we put on a total of 13 outriggers from Innovative Machine, 7 on slide side & 6 on door side it seems to be fine now. I do have a list of parts I used if anyone wants them.
PLEASE report a safety problem on the NHTSA web site( upper right of their web page) so as to force Forest River to do a recall, and maybe reimburse us for this. |
