mjlrpod
Topic: Adding a couch Posted: 16 May 2021 at 11:41am |
Originally posted by Pod People
Sorry-should have first said.... MJLRPod - Nice job!! I'm sure it is both more attractive and more comfortable. A great improvement. Vann
Thanks, It makes the space so much larger when the slide is out, but just abit smaller when it's in. It's really comfortable, and makes a wayyyy better bed than the dinette did. I think you could sleep two adults on it, as long as they know each other very well. If they didn't, they will by morning, lol. As far as the ottomans, there was nothing in mine. The only wiring was on the left side of the photo, under the small 1.5 square rail I used to attach the sofa.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Pod People
Posted: 15 May 2021 at 5:31pm |
Vann & Laura 2015 RPod 179
Pod People
Posted: 15 May 2021 at 5:29pm |
Rawest-
MAYBE,You are asking from your 179 point of view about a 196 placement- I also have a 179. I "think" the difference is that the 179 does have wiring/plumbing in the left ottoman and apparently, the 195 ottomans are empty and the wiring/plumbing is routed in a different location. The 179 could have a couch in the slide out, but you are correct that something would have to be done about the plumbing/wiring in the left ottoman. It would stick above floor level. Or you could simply leave the left ottoman with a cushion on top and adjust the ottoman base height so that the top of the cushion is still level with top of couch and couch can slide over ottoman base(with cushion removed)when slide out retracted. Whew! that was a long sentence.
Hope this helps Vann
mjlrpod
Posted: 15 May 2021 at 2:46pm |
Originally posted by rawest50
I just removed the ottomans, cushions, etc. with the jack knife sofa. How did you handle mounting the sofa and the legs? You have the electrical and plumbing under the left ottoman? I would love pictures.
I mounted the sofa without legs. Not needed as the dinette frame was at the proper height, so I put it right ontop of where the cushions used to sit. It was a pretty easy install. I had a couple small wires that ran along the edge of the pantry ontop of the dinette frame, but I put a large 45 chamfer on the edge of the post I used to attach the couch to the dinette frame. That allows the wires to be under it, but nothing is touching them.
2020 R-pod 195
I'll be rpodding
rawest50
Posted: 10 May 2021 at 6:01pm |
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
rawest50
Posted: 29 Mar 2021 at 3:46pm |
Is you couch area in a slide out? If so is the electrical under the left ottoman facing it? If that is the case how did you handle the electrical in the ottoman attached to the floor?
2017.5 RPod 179
2 Weiner dogs
mjlrpod
Posted: 21 Mar 2021 at 1:06pm |
Originally posted by GlueGuy
That looks pretty good Mark. Are you planning to bolt it into the dining nook? |
My plan is removing the 2 ottomans, and all dinette cushions. Then I will make two rails that attach to the bottom frame of the couch. Then i'll bolt the two rails to the dinette platform that already exists. The couch is 72 long, and the opening is 75, so an 1 1/2 rails on each side will fit perfectly.
2020 R-pod 195
I'll be rpodding
Posted: 20 Mar 2021 at 11:03am |
mjlrpod
Posted: 19 Mar 2021 at 11:08am |
got this one, Wife didn't want anything dark. I haven't opened the box yet, still to cold to go out and start this project.
2020 R-pod 195
I'll be rpodding
Pod_Geek
Posted: 19 Mar 2021 at 10:30am |
Which RecPro sofa did you get? Been considering the same modification.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
