  New Posts New Posts RSS Feed: Possible replacement for the A/C
Topic ClosedPossible replacement for the A/C
 Post Reply Post Reply Page  <1 34567>
Direct Link To This Post Topic: Possible replacement for the A/C
    Posted: 10 Jul 2012 at 7:32am
That vent helps to remove any moisture, and to prevent freeze-ups in cold weather.  I've thought about cutting a hole in the floor under there and mounting a biscuit fan, to push fresh air into the cabin during boondocking trips.  Without A/C you have to leave the windows (and vent) cracked to prevent moisture buildup but that is difficult when it rains.  No reason you couldn't do the same for an A/C like you said.  I would use that as the air return and put the cold air output somewhere else, up high.  Maybe use a removeable hose attached to something that would let you use one of the front windows.  That would eliminate the need to make a hole in the exterior where it is visible, so if you sell in the future you could remove the whole thing and you would never know.
Edit:  In my case, with a 171, I might run another pipe underneath and run it up behind the fridge and microwave, venting it from the storage area above the microwave.  Very close to the existing A/C.  However, as a proof of concept I would just use vents through the windows first.  Wouldn't add much extra setup time in camp - but knowing me I would keep that as a permanent solution!
Seanl View Drop Down
Direct Link To This Post Posted: 10 Jul 2012 at 7:13am
I would be willing to find out by using a $200 window shaker and reconfiguring it.  Not sure I would want to try with that $600 thing.  But they do suggest using it with a small RV...
The only issue with moving the controls is that the thermostat on most window units has a temperature probe that goes in front of the cooling coils. This probe is only about 24 inches long and I don't  know if it can be extended. I looks like a thin copper pipe.
Also just to note. I have had a window unit in my homemade trailer for 4 years with no issue. Also some tent popups and other small commercial trailers have window units in them.
plains View Drop Down
Direct Link To This Post Posted: 09 Jul 2012 at 10:42pm
Has anyone noticed the the vent under the bathroom door? To my knowledge, it doesn't actually serve a purpose (other than access and possibly keeping that space somewhat conditioned?). I wonder if there would be a way to run a duct from a unit mounted on the tongue, under the dinette in the storage space, (assuming yours in the front like mine), and to this vent? Seems like a pretty clean install, and the only thing left to figure out would be how to remove the controls from the unit on the tongue and mount them in the interior.
Direct Link To This Post Posted: 09 Jul 2012 at 10:27pm
ka9nyn View Drop Down
Direct Link To This Post Posted: 08 Jul 2012 at 4:34pm
My concern, perhaps already addressed: Can this unit/system handle the vibration, etc. from road travel, in the short & long term? It appears to be designed for static installations. Just a thought...
Dave & Rose
RP177 "ECM-Pod"
'08 Dodge RAM quad cab 5.7L 4WD "Rhino (re: F-4 Phantom)"
Chamberlain, SD (Formerly: Rockford, IL)
2010 RP 177
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 08 Jul 2012 at 2:49pm
We don't have air in our house, but run a window unit in the bedroom.  This morning I hooked up the Pod to the generator and turned on the air.  It is quieter than the window unit, and the compressor starts with no thump or bump.  I can tell when it is running, but just from a sound change.
I also wanted to troubleshoot the television.  I haven't gotten reception the last three trips and knew I would get reception at home.  The first two trys no go.  Then I pushed the little light that used to be lit on the back of the cabinet to tell me that the antenna was powered, and it clicked!  A switch!  Then all the stations I could use.  Go figure.  Maybe by the third season I will know how to run this camper...
2011 R-Pod 177
2010 Ford F-150
XJ2202009 View Drop Down
Direct Link To This Post Posted: 08 Jul 2012 at 2:41pm
I would just mount them in a plastic case inside the camper and run the wires out
2011 176T
06 Trailblazer ext ls, 4x4
wife, 4 kids
Direct Link To This Post Posted: 08 Jul 2012 at 12:35pm
Hmm, something to ponder.
Direct Link To This Post Posted: 07 Jul 2012 at 5:13pm
I just took apart an old window unit I had.The control section its the only part that wound have to be sealed.I think that I would mount them in a waterproof electrical box.
Direct Link To This Post Posted: 07 Jul 2012 at 2:31pm
Yes, I have an A/C, but the noise is my biggest complaint about the pod. The one on my popup was much quieter. The hole is a standard vent/fan size so it will be easy to replace it with a vent.
Modifying a regular window A/C is an interesting idea. The hardest part would be sealing up the "inside" part since it cant get wet.
