Possible replacement for the A/C |
Post Reply | Page <1 567 |
Topic: Possible replacement for the A/C Posted: 19 Aug 2014 at 12:37pm |
Agree, it sounds like you are talking about the GFCI outlet and not the breaker in the converter. Two different things.
Julia1961
Newbie Joined: 23 Aug 2013 Location: Florida Online Status: Offline Posts: 29 |
Posted: 19 Aug 2014 at 11:13pm |
I am not sure where that plug is, I have an outside plug in with grey cover on it on the outside of pod, but did not know there was one underneath. I have a 173 do you know where I tut located underneath? Near dorr, by stair sect. I am sorry this seems like a dumb question but I have never seen a plug underneath....
The Vintage Glamper
Lilly Pod |
Posted: 20 Aug 2014 at 9:50am |
Sorry, no plug under the pod, I was referring to running a extension cord under the pod, into the dome, from the power pedestal. Most pedestals now days have a 50A, 30A and 15/20A plug. Using a extension cord to power whatever you have going on in the dome is a pretty standard thing to do..
When discussing power issues in/with the pod, there are breakers at the pedestal, breakers in the pod, fuses in the distribution panel, fuses on the converter, and then the GFCI outlet. Those are all places that can be a "supply issue". Some GFCI outlets are more sensitive then others.. and I suspect that to be your problem. |
Julia1961
Posted: 24 Aug 2014 at 4:33pm |
We stayed at the Suwanee River on my first maiden voyage, they did have a 30 amp but only one and I ran my pods shore power off of that.....it did not have all the other fancy stuff in you picture I guess I cant use the out side plug unless I stay somewhere where they have the extra amps.... :(
Thanks for your feedback, any additional will be apprecitate...love my group here..! Lillypod.....JUlia |
The Vintage Glamper
Lilly Pod |
Posted: 24 Aug 2014 at 8:27pm |
All of the outlets on your pod are powered up when you have the 30 amp plug plugged in, including the one on the outside.
Band Leader
Groupie Joined: 23 Apr 2015 Location: NCo Online Status: Offline Posts: 51 |
Posted: 11 Nov 2015 at 8:21pm |
Has anyone simply swapped out the AC for a quieter unit? Does that help? Will anything quieter fit?
2016 R Pod 178
2001 Ford F 150 Triton V8 Kayaks and old folks bicycles |
Posted: 13 Nov 2015 at 7:08am |
The ones I mentioned earlier in this thread should be quieter. While I didn't make the swap, Kickstart did (see page 6 of this thread). I don't think we got a final report on the noise level.
Wojak
Newbie Joined: 16 Apr 2018 Online Status: Offline Posts: 2 |
Posted: 17 Apr 2018 at 12:41am |
Somewhere in this forum I’ve read to turn the fan to auto for that situation.
Wojak
Posted: 17 Apr 2018 at 12:43am |
That is when using your furnace and don’t want a/c fan coming on.
