Ball Mount Question |
Post Reply | Page 123 4> |
Topic: Ball Mount Question Posted: 28 Nov 2020 at 4:09am |
It’s an interesting question.
It’s possible that the two could interact depending on what sway control system you have. I understand for example that Blueox wdh/sway control comes with a warning to shut off TSC. Blueox is not a friction based sway control system, it uses tension in the wdh spring arms to apply torque to the trailer to straighten it out. Think of it as a dynamic sway control where the trailer sway is being controlled by two springs, one on each side. In comparison straight friction bar sway control dampens trailer side to side motion passively. So, conceivably TSC trying to actively operate your truck brakes on either side one at a time could get out of phase with the action of the blue ox spring bars and make the sway oscillation worse. A passive friction sway system with no spring action couldn’t do that. So my recommendation would be to get a wdh with friction based sway control and leave your TSC engaged. Sway control systems are all secondary to having a properly loaded trailer to begin with. That means having at least 10, preferably 11-12 percent of the trailer total weight on the tongue under all load conditions, so that the trailer center of gravity is well forward of the trailer axle. When the c of g is too far aft the trailer wants to swap ends when you hit the brakes or get a crosswind. The only way to know that is to weigh it. Check out this video: https://youtu.be/i2fkOVHAC8Q |
Posted: 27 Nov 2020 at 7:34pm |
SkeeterPod11
Newbie Joined: 28 Oct 2020 Online Status: Offline Posts: 16 |
Posted: 27 Nov 2020 at 6:34pm |
My 2021 Tacoma SX comes with electric sway control build. Do you like this will conflict with a sway control that is part of the WDH..?
Posted: 27 Nov 2020 at 6:13pm |
I use the Reese pro wdh with independently
adjustable sway control. It take a couple extra minutes to hitch up but to me it’s well worth it to be able to adjust the sway control separately from the wdh. There are times when I like little or no sway control (slick roads, windy mountain roads) while leaving my wdh tension unchanged. With many systems you don’t get that choice. |
GlueGuy
Posted: 27 Nov 2020 at 5:20pm |
The only one I know who has used more than one kind of WDH is StephenH. For me (and most others I would assume) after I got and used the E2, there was no compelling reason to switch. It works, I think it's pretty simple to setup and use. Done.
EchoGale
Senior Member Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 463 |
Posted: 27 Nov 2020 at 4:02pm |
I have the Anderson and like it. I haven't used any of the others to compare though. It is supposedly lighter (which was a thing for me) and the customer service has been great. A year and a half on and the pin bent. When I called them they said they had redesigned the plate and sent me the new part for free.
Julie
SkeeterPod11
Posted: 27 Nov 2020 at 3:44pm |
The Anderson “No-Sway” Hitches do look a little more user friendly. Higher price. But not a deal breaker. Anyone else have any experience with Anderson hitches appose to other WDH such as e2 or curt..?
geewizard
Senior Member Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Posted: 27 Nov 2020 at 7:23am |
GlueGuy
Posted: 26 Nov 2020 at 12:48pm |
It's not terribly difficult to install, and there are easy workarounds for he high torque requirements (see above). We bought the E2 and the RP179 together as a "package", and the dealer set it all up.
podwerkz
Posted: 26 Nov 2020 at 12:32pm |
It would not be difficult for Curt or any of the receiver shank manufacturers to integrate some kind of dampening bushing....a simple twist of a bolt could expand a rubber bushing in the shank, pushing thru a couple of openings and reduce the clunking to a minimum....hmmm...but I guess I need to patent the idea first!
