  New Posts New Posts RSS Feed: Outriggers  Forest River parts
 Post Reply Post Reply Page  <1 23456 13>
pedwards2932 View Drop Down
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Topic: Outriggers Forest River parts
    Posted: 04 Oct 2021 at 2:15pm
I finally recieved my outriggers.....no screws and they weren't painted.  I intend to use TEKS screws.  I am going to space them evenly front to back 4 on each side.  Everyone has been saying put them under the rollers for the slide out?  My slide out is on tracks that are midway up on side of slide out.  Where are the rollers?
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2021 at 1:05am
Actually the stress on the screws attaching the outriggers to the frame are axial not vertical. As the floor sags it pushes downward on the outer ends of the outriggers trying to rotate them. So the upper screws go into tension while the bottom ones are pretty much just along for the ride.
That being said TEKS screws should work fine. Assuming they are 1/4-20 and knowing that the frame tube thickness is 0.1 inch gives an allowable pullout load
of about 430 lbs.
If the outriggers are 10 inches long (how long are they actually?) and the attachment screws are placed 3 inches apart in the frame tube then each pair of screws should be good for about 3/10*430=130 lbs. There's really not that much load from the sagging wall due to rpod light construction so I'd guess an outrigger every couple feet would be fine.
Of course, if you have room to through bolt and use a large flat wwasher on the inside (don't overtighten and compress the frame tube!) then that would be much stronger and you could use fewer outriggers in those areas.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2021 at 2:14pm
The down side of using the screws or nuts and bolts for that matter is the placement of the tanks. They are too close to the rails to allow one to get in there to use bolts and if one uses screws and goes through both walls, one runs the risk of puncturing one of the tanks in the process. Since the black water tank is the one in question, that would be an ugly scene. I used shorter screws on the ones that would be at the tank location and went through one wall of the frame only. I figured the major stress would be vertical. Besides, I had already installed two homemade outriggers and bolted them. i installed two of the FR outriggers. I still have two that I need to get installed on the door side.
PilotPodder View Drop Down
Post Options Post Options   Quote PilotPodder Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 6:54pm
Yeah, my cargo bay water leak was very disappointing. Strange, but none of my appliances have even acted up on my 179 in 5 full seasons, but the structure, especially the floors, are just not supported well nor are they made of the best materials. My Keystone Bullet 243BHS RV that I use for longer trips, has the new Hyperdeck composite flooring and its structure is rock solid vs the Pod. However, I have had issues with almost everything with a Dometic label on it, including getting the A/C replaced within 18 months! It would be nice if someone could get a composite floor, Azdel walls and better appliances in one RV! ~PP
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 11:38am
Ok did you post any of the pics?  I still can't find any pics.  I did look at your videos as well.  I saw that you had the same issue as I did that caused your flooring in the storage area to get wet.  FR did a horrible job on my 189 at the joint where the walls meet the front.  They cut the wall improperly and tried to use a ton of screws to hold it together.....it all came apart while traveling and I had to relaminate the sides at the bottom edge.  It is rediculous that mine in a 2018 and I just want to use it for 2 to 3 years as I am 68 now and I am not sure it will last that long.
Post Options Post Options   Quote PilotPodder Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 10:05am
I don't have the R-Pod with me currently, but the pics I took do show three supports (outriggers) welded, one near the front and two near the axle.
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 8:44am
I can't seem to find any pictures of a factory install of these outriggers?  When I ordered them and asked the parts person if there were any instructions on installation and location for them she said FR didn't have anything but I should be able to find instructions on internet?
Olddawgsrule View Drop Down
Post Options Post Options   Quote Olddawgsrule Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 2:55pm
Originally posted by offgrid
You don't have to weld them.
FR suggests using TEK self drilling screws and shooting them through both walls of the frame rails. Or you can through books them but if you use a flat washer and don't compress the frame tube by overtightening. It's walls are only 0.1 inch thick.
That in it's self is a good reason not to play any deeper. You folks know my opinion of FR and these risers..
Basically what I will say is this 'NOT' an off tar rig and thinking that raising the clearance of the Pod will get you there.. Well... I do wish you luck and chance that I meet you out there with my rig, I will 'try' to help.
Adding a longer section of 2x2 tube(about 4ft long) will get you there with some additional support. Just adding the risers they sell... with TEK screws holding them.. Not in my lifetime.
Safe travels folks!
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
JA-Pod View Drop Down
Post Options Post Options   Quote JA-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 2:54pm
John,  I checked my 2017 (Green ver) and no outriggers at all,  so they must have added them in the 1/2 year change  to be installed on your 2017.5  are they welded or bolted on?
John & Allison
R-Pod 179 (2017)
Nissan Frontier SL V6 4.0 (2019)
Post Options Post Options   Quote JA-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2021 at 2:31pm
good question on the optimal place to install them,  I went with all 4 under the slide as directly under the rollers as i could get,  logic to me seem this is where the most pressure would be on the side of the trailer.  Not an engineer here though,   on this forum there are others well versed in the engineering world
John & Allison
R-Pod 179 (2017)
