Gas Mileage |
Post Reply | Page <1 1617181920 21> |
brownd
Newbie Joined: 25 Jul 2010 Online Status: Offline Posts: 36 |
Topic: Gas Mileage Posted: 24 Aug 2010 at 2:43pm |
I was going to respond to the 1st set of math being too low but I see techntrek has already done that. If one extrapolates his $43 dollars saved each 1000 miles at 2.5 mpg improvement then take the 50000 mile potential lifetime of the pod and multiply his $43 /1000 miles saved times 50 and that is $2150 over the lifetime of the pod. 5 mpg would double that. That is not too bad.
I second his opinion that the power regained from less drag on the vehicle should both lengthen the life of our transmissions, especially on six cylinder suv's, and allow us to travel with ease at 55 or maybe even 65 mph. Right now my jeep is struggeling a good deal of the time at 55 in 3rd gear and 2300 rpm or more. At 50 as I stated above the line of traffic behind is both embarrasing and kind of dangerous until you let them by.
I really want to thank Forest River for responding to Techntrek and for him exploring this with them. They have a great product that is hindered by just this issue I think. If they could talk to folks through their dealers and advertising that they have worked with owners to obtain better mileage and improved performance pulling the Pod for a 6 cylinder vehicle equiped to pull 3500 that would be a marketing plus for them. I would love to go out and experiment with different air deflectors or spoilers but can't afford to do it. If there were an aftermarket item either to add to the pod or the automobile that was reasonably priced and documented to work with the Pod, I would snap it up in a minute.
Dave
Posted: 24 Aug 2010 at 12:57pm |
This had been edited, someone pointed out an error in my math. Changes are bolded.
1000 miles/10 mpg = 100 gallons used
1000 miles/15 mpg = 66.6 gallons used... 33.3 saved from 10 to 15 mpg, or $100 saved @ $3 per gallon
1000 miles/20 mpg = 50 gallons used... 16.6 saved from 15 to 20 mpg, or $50 saved @ $3 per gallon
So it looks like there is an increasing return depending on where you start. In my case, using only a 'pod spoiler, I would go from 12 mpg to 14.5 mpg:
1000 miles/12 mpg = 83.3 gallons used
1000 miles/14.5 mpg = 69 gallons used
14.3 gallons saved, $43 saved over every 1000 miles.
However, I'm much more interested in getting some power back at highway speeds for uphill climbs and passing. I always had lots of extra "umph" pulling my popup even though it was many hundreds of pounds heavier than the 'pod. Passing a semi on an uphill climb was no problem, now I'm getting passed by the semis.
Butterfly_Lee
Senior Member Joined: 19 Nov 2009 Location: Corpus Christi Online Status: Offline Posts: 131 |
Posted: 24 Aug 2010 at 10:41am |
I would be very interested in an after market spoiler. An added plus would be a channel for the water the runs down from the A/C. Plus with less turbulance in the back would there tow be easier? So in theory..back spoiler = plus 2.5 mpg and front wedge = plus 2.5 mpg
5 mpg gain over 1000 mile trip = 50 miles = 3.33 gallons saved at $3.00 per gal = $9.99 SAVED
So lets say we plan travel 50,000 for the life of the POD, which is 499.50 dollars in fuel cost saved. With all the additions, which cost how much?.
Check my Math, I'm looking a cost effectiveness.
Lee
Still a work in progress, lots of pictures.
http://podterfly.blogspot.com/ |
Posted: 24 Aug 2010 at 8:59am |
Good afternoon Doug I just got back into town from a week long road trip. The spoiler design came from the people that make our fiberglass rear cap. It was not intended to be a spoiler, they came up with the design strictly for cosmetic purposes. It was never intended to be a spoiler. We're not sure if there is any improvement with the spoiler. Do you think if we were to develop a rear spoiler it would be beneficial??? and what do you think about us developing an after market rear spoiler?? We haven't looked into it, but what are your thoughts. Please let me know and hope this helps,
Based on the posts from the link, I think you would have a market for one *if* you can demonstrate that it would lower drag in real-world tests. The computer simulations (also on that thread) show a high disturbance area on the tail area which would explain why so many of us feel a sharp drop off in available power above 50 mph. I think the appearance of a spoiler on the back would complement the existing curves, maybe make it look “sporty”, so it shouldn’t be a problem for those of us that bought it because it is so different. I’ll pass on your questions to the forum to get more input. |
Posted: 24 Aug 2010 at 8:58am |
Did you have an overall increase or decrease in altitude between home and Codorus? That slight difference could be explained if you lost/gained several hundred feet in either direction.
brownd
Posted: 24 Aug 2010 at 7:36am |
Yes it would be interesting to see what a the computer model says, but the best test is if the loading of the kayaks can be reproduced with the same results of around 13 mpg. If so then it appears that a spoiler/air diflector on the car would do some good. Thanks for the observation.
Dave
Butterfly_Lee
Posted: 24 Aug 2010 at 12:43am |
Were you getting wind noise when boats were in the shape of a V? You need to run that image on the airflow model. Looks like that v-shape was high enough to deflect the front shape of the POD, is it physically wider and higher? If nothing else it appears it would deflect about 80 percent of the front airflow.
Interesting. Lee
rpodcamper.com
Admin Group - pHp Joined: 26 Nov 2009 Location: Reading, Pa Online Status: Offline Posts: 3990 |
Posted: 24 Aug 2010 at 12:01am |
OK I had a strange one that I found out by mistake. I went to Codurus State Park which is about 80 miles from my home with the kayaks on the roof. I had just thrown them up their in a hast and did not notice that the front was closer together than the back (basically making a large V). I averaged 13.1 miles to the gallon from the computer in the car. I then like a stooge fixed the kayaks to make them straight for the ride home and the computer showed 11.2 miles to the gallon (but no wind noise from them).
brownd
Posted: 23 Aug 2010 at 10:59am |
Tidalwave,
I guess your last posting says it all. It is wind resistance and not weight that is preventing decent performance and reasonable mileage on 6 cylinder engines and for v8s you get the performance but mileage is still bad even at slower speeds. My experience with the Jayco popup as I stated when I opened this discussion was 17 mpg with no problem. As Outbound said earlier we are towing a barndoor (a pretty comfortable one when you get to camp) down the road.
It sure would be nice to hear from someone who has tried a spoiler of some sort or the 173t that already has an experimental spoiler from the factory.
Dave
TIDALWAVE
Senior Member Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Posted: 21 Aug 2010 at 9:01pm |
I just came back from a camping trip and encountered an "A-Liner' owner who hauls the largest
version. His A-Liner weighs significantly more than my Pod but is able to lower the 'walls/top' like a tent camper. He also pulls his A-Liner with a Chevy pickup identical to mine in engine and transmission. He gets about 14-17mpg. Which is about 30% better mileage than what I have been getting. It seems that pulling anything higher than your tow vehicle really cuts the mileage! |
TIDALWAVE
