Replacing interior lights with LED's |
Post Reply | Page <123 |
Author | ||||||||||||||||||||||||||||||||||||
popgoesweasel
Groupie Joined: 22 Jan 2010 Location: Costa Rica Online Status: Offline Posts: 49 |
Topic: Replacing interior lights with LED's Posted: 19 Jul 2010 at 11:50am |
how about some links to the bulbs that you have as replacements or the LED arrays that will generate enough light for reading.
I went to the web site but our pod is not where we live, I cannot figure out when are the correct replacement bulbs.
R171 2010
Frontier 2009 Site 40 Eastern Rally 2010 |
TerryM
Posted: 19 Jul 2010 at 7:01am | |||||||||||||||||||||||||||||||||||
Happy to see your results. I am planning on replacing my lights with LED's also. From the same place even! In the motorhome I had I replaced the lights with florescent lights and that made a big difference also. But LED's are much better at saving juice.
Terry |
Posted: 18 Jul 2010 at 9:27pm | |||||||||||||||||||||||||||||||||||
A great way to shed some load, thanks for the info.
pod-head
Newbie Joined: 16 May 2010 Location: PHX Online Status: Offline Posts: 9 |
Posted: 18 Jul 2010 at 7:49pm | |||||||||||||||||||||||||||||||||||
Part II (Continuation from the post above)
So, since the multimeter was already connected to the battery, I decided to measure the other possible 12V loads in the pod:
(1) The baseline load is the fridge running on propane,with CO2 and propane detectors on; no lights or other appliances running. |
'10 RP177 towed with '10 Tundra D and T, and sometimes Nala the cat |
pod-head
Posted: 18 Jul 2010 at 7:45pm | |||||||||||||||||||||||||||||||||||
In an effort to maximize the battery life for our annual week-long boon docking trip, I recently ordered some LED's to replace the interior lights. We finally had a weekend to go camping, so this project was at the top of the list. Since I already had the multimeter out, I decided the check the current draw of the regular bulbs vs. the LED replacements. Wow-- what I found was really surprising.
***The fine print: These LED replacements are about 1/2 as bright the standard bulbs. They are adequate for eating or playing a game, but it might be difficult to read something with, uh, fine print. I just went back to the website (superbrightleds.com) and ordered some larger LED arrays that will generate more light. I'll report back when I have a chance to test these. I turned on one of the double overhead lights (RP177) and found it used 2.460A. I replaced the bulbs with the LED's and remeasured the current at 0.040A. Thats less than 2% of what the std bulb used. Thats huge! So let me put this into a battery life perspective. If you have a 75Ah (Amp*hour) RV battery, you could estimate that it would sustain a load of 1 Amp for 75 hours (under ideal conditions, battery capacity is effected by load, other factors effect capacity, your mileage may vary, blah, blah, legalese). Using the numbers from above: std bulb: 75A*h/2.460A => 30.5 hours of use LED array: 75A*h/0.040A => 1875 hours of use Thats a BIG difference. |
