WDH or no WDH??? |
Post Reply | Page 123 4> |
ArenaBlanca
Senior Member Joined: 07 Sep 2016 Location: Alamogordo, NM Online Status: Offline Posts: 158 |
Topic: WDH or no WDH??? Posted: 20 Sep 2019 at 9:07am |
Three years ago while in northern NM, we purchased a 179. I bought a 2 inch ball from a local Tractor Supply store and towed the 179 home to southern NM with my 2004 ¾ ton pick-up. The ride seemed a bit bouncy and sway was noticeable when I got caught in a dust devil. So I replaced the shocks (they were the original shocks for the truck) and added a sway control bar. The trailer connection for the sway bar was welded onto the camper frame. But the combination of new shocks and the sway bar solved the bounce and sway issues. Last week we traded our beloved 179 for a new 195 from the same dealer in Colorado. Because this was a trade and part of the sway control was welded to the camper frame, I towed home without sway control. The tow vehicle was the same ¾ ton pick-up. It is a diesel and only has 140,000 miles on it. The ride also seemed a bit bouncier than I was used to but I figured this was due to the extra tongue weight of the 195. I feel safer with sway control although many believe I don't absolutely need it with this tow vehicle. So I am planning on adding sway control. I am wondering whether a weight distributing hitch would dampen the bouncing as well provide sway control. If so, what make and model would you suggest?
Enjoy Life!!
GlueGuy
Posted: 20 Sep 2019 at 9:52am |
We pull with a 2015 F-150, and we find the WDH makes the trailer+truck move together as more of a "unit". We believe we could tow without the WDH, but we like the combination better with it.
ArenaBlanca
Posted: 20 Sep 2019 at 11:39am |
I was thinking the same thing. Do you have a suggested make/model? I have a WDH for another camper but that camper has almost 900 lbs of tongue weight.
Enjoy Life!!
Posted: 20 Sep 2019 at 5:20pm |
5 years with a Chevy Silverado 4X4, 2015 178, sway control, no WDH, no issues. It's a personal choice. Last time I had a WDH was a 25' plus Airstream, towed with a 3500 Chevy dually. My current tongue weight is @370.
Posted: 21 Sep 2019 at 6:28am |
+1. With a 3/4 ton pickup, you shouldn't need a wdh, but you might prefer the ride with one. Sway control couldn't hurt. Some wdh's have integrated sway control, some are completely separate systems.
Pod People
Posted: 21 Sep 2019 at 8:04am |
We tow our 179 with a Ford Expedition El. I'm sure we don't NEED a wdh--however, I am also sure that the wdh adds a safety factor in 2 ways that it is designed for. One, it does help the ride by making the tow vehicle and rpod more of a unit as well as leveling the vehicle. secondly, the anti-sway properties have made it safer and also peace of mind. This is our second rpod-we had a 173 prior to the 179. we have towed both units all over the country, including 2 cross country NC-California round trips. We have never experienced sway. We use an Equalizer 4 point hitch system with 600 pound bars for both pods withut issue. maybe the best $550 I have spent on rv items. There are several other important considerations in thinking about eliminating sway. Good tires(Goodyear Endurance ) with a stiff sidewall and properly inflated go a long way in eliminating potential sway issues. the second important thing is properly loading the pod with weight forward of the axle and having the correct amount of tongue weight. tow vehicle suspension and the pod being level when towed are also considerations. Vann |
crankster78
Senior Member Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Posted: 21 Sep 2019 at 8:59am |
Greetings: I have owned 2 pods and for years I did not have a WDH. I purchased and installed one this past spring. I have found that it does make a difference even with my long wheel base PU. It is easier to steer, feels better on the road, It reduces wear and tear on the truck. It was a good investment. My 179 has dual LP tanks and a electric hitch jack, so it very likely has a hitch weight in the upper 400 pound range. The hitch I installed is a Equal-izer R3 Crankster78 F-150 R-179
Crankster 78 R-179 2015
GlueGuy
Posted: 25 Sep 2019 at 6:13pm |
I just came across this article as a link attached to a story about someone's receiver failing, and losing their trailer (it was in a campground, and at low speed, so no great damage was done). It is interesting as it states the "general rule" is that you "should" use a WDH if the trailer weighs more than 50% of the tow vehicle weight. To quote the statement:
The owner's manual of our F-150 recommends using a WDH if the tongue weight is over 500 lbs. That is well above the recommendation of the above article, but none-the-less there is a lot of good information in this article and all in one place. Not a bad place to start.
Posted: 26 Sep 2019 at 5:46am |
The basics of this article are fine, and it gives a great explanation about how to weigh your rig at a public scale.
I don't agree though with their hitch recommendations (other than the Hensley being the best of the best). The Anderson chain system is under a lot or tension so puts some weird stresses on the trailer frame. Despite their disclaimers it sure reads like an Anderson advertisement....I'll stick with spring arms myself, thanks. Also, the weakness of the designs where the spring arms also provide the antisway friction is that you can't separately control the two functions. That is probably fine for most folks but I like being able to set up the two functions independently. I often want to have full weight distribution with little or no antisway when on wet pavement or low speed twisty mountain roads. And, when backing into a tight campsite it only takes a couple of seconds to take off separate antisway bars because they aren't under tension. |
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Posted: 26 Sep 2019 at 6:30am |
I tow with my Tacoma. I would think the same option for all 1/2 ton TV's..
What's the thought on air-bags vs. WDH. |
