multimeter purchase |
Post Reply | Page <123> |
ColoradoPK
Newbie Joined: 04 Dec 2018 Location: CO Online Status: Offline Posts: 21 |
Topic: multimeter purchase Posted: 18 Dec 2018 at 4:58pm |
I figured it would be a good idea to have to keep
Track of battery power? |
PK Colorado
Posted: 18 Dec 2018 at 4:52pm |
What is the goal for the voltmeter?
Posted: 18 Dec 2018 at 3:44pm |
That is why I waited until the Southwire meter was at a price point that was acceptable. It looks to be a good quality meter, much less expensive than a Fluke meter but much higher quality than ones like the GB described above.
Posted: 18 Dec 2018 at 2:27pm |
I would precaution about Gardner Bender (usually labeled "GB" on the front, and orange/black or just orange). They're OK meters as far as they go, but I picked up a couple of cheap GB meters when I didn't have access to my own meter, and they came apart (internal rotary switch failed) after not a long time. You can often pick up one of these GB meters for $15 or $20. I don't think they are worth that much.
TheBum
Posted: 18 Dec 2018 at 1:49pm |
Not all of them retain calibration well though. I trust the better brands to maintain calibration more than the cheap meters. |
Alan
onesojourner
Newbie Joined: 23 Nov 2018 Location: The Ozarks Online Status: Offline Posts: 29 |
Posted: 18 Dec 2018 at 1:26pm |
DMM are pretty good now days. I have a $10 craftsman, a $50 RadioShack and $200 fluke. For most tasks they all work. I usually grab the cheapy because it is a bit lighter. I would just buy a cheap one with decent reviews and add a clamp on meter.
TheBum
Posted: 18 Dec 2018 at 10:22am |
Fluke is a good brand too.
Alan
CharlieM
Posted: 18 Dec 2018 at 9:16am |
+1 to comments from StephenH and Glueguy. The ability to measure DC current is a big plus with battery charge/discharge management. A word of caution: If you do decide to go with a clamp on meter be sure it measures DC as well as AC current. Most of the cheaper meters only measure AC current. Also, the lower current range meters are preferable. The is no need for a 1000A meter on an Rpod. The 40A range on the above cited meters is ideal for your use.
Posted: 18 Dec 2018 at 9:08am |
As TT mentioned, almost any inexpensive DVM will work well for what you need on an R-pod. Even if it was off by 1/10 volt (which none of them are any more), it wouldn't make a big difference in what you're looking for. Also as mentioned, having a non-contact voltage sensor (NCV) is a big plus. You can get a separate sensor for not too much, or you can spend a few dollars to get NCV built-in. A third thing is a current sensing clamp. You can get meters now that can sense both AC and DC current with a clamp. This is very handy, as in the old days you would have to "open up" the circuit to sense current. With this, all you have to do is find a wire and clamp around it. I have two meters. A Fluke, which I got for my business, and I love it very much. For the R-pod, I got a Klein CL800, which is auto-ranging, has NCV, as well as a current clamp. Kind of an all in one tool. I think I got it at Home Depot for a little over $100. |
Posted: 18 Dec 2018 at 8:09am |
I purchased a Southwire 21050T Tre RMS AC/DC Clamp Meter at Lowe's recently. It not only is able to measure AC and DC voltage, it can also measure AC and DC amperage (400A) and also has a non-contact voltage sensor built-in. In addition, it comes with an adapter and a temperature probe on a cable. Previously, I only had the little free with purchase digital multimeters from Harbor Freight. This is absolutely much better. It was more expensive, but worth it since it has already helped me to see parasitic drains on 12V power that I could not measure before.
