Bearings and Wheel Problem-Twice |
Post Reply | Page <1234> |
CAhikers2x2
Newbie Joined: 19 Jul 2017 Location: SF Bay Area, CA Online Status: Offline Posts: 12 |
Topic: Bearings and Wheel Problem-Twice Posted: 20 Nov 2018 at 9:34pm |
Thank you for sharing. This sounds like we have some similar symptoms. The brakes wanting to stop quickly and the wheels not vertical to the ground...is this called camber? On trailers like our pods, are the wheels supposed to be at a vertical camber?
We do have the west coast Hood River Edition with the beefy tires so tire wear is something I would not notice. Somewhere I recall the Hood River Edition having a "dropped axle". Is this so and is this common with other trailers? Many thanks, this sounds so similar. Joanne |
Roger & Joanne
1 Camper Dog "Scout" 2015 RP 177 2016 Nissan Frontier 2001 Coleman Westlake |
Posted: 20 Nov 2018 at 10:19pm |
See this for an explanation of camber: http://blog.easternmarine.com/trailer-axle-camber-what-its-all-about/ Also, see the Trailer Axle Owners Manual: http://www.lci1.com/assets/content/support/manuals/Trailer-Axle-Owners-Manual.pdf I'm, not sure what you mean about a "dropped axle." It could be the angle of the arm to which the spindle is attached. On mine, it is angled a little upward. It was set to a downward angle starting in 2017 (I think). Mine has riser blocks but the ones with the re-clocked axle did not come with riser blocks although they can be added for even more height. I can't find any thing about a "dropped axle" when I am searching. |
CAhikers2x2
Posted: 21 Nov 2018 at 1:23am |
Thanks Stephen for helping me understand more of the mechanics of our Pod. I will check these links and pursue where I picked up "dropped axle". I could be using the wrong terminology for exactly what you are telling me. Our Pod does seem to sit high off the ground. But it came standard that way because of the large tires. Everything was stock, from my understanding when we purchased it new.
I have been overwhelmed with everyone's great interest. Thanks again, Joanne |
Roger & Joanne
Posted: 21 Nov 2018 at 7:23am |
We are both looking for answers on this issue. When I hear from the dealer's service department, I will let you know.
Woodmiester
Senior Member Joined: 03 Aug 2018 Location: Greenwood IN Online Status: Offline Posts: 142 |
Posted: 21 Nov 2018 at 8:18am |
All of these issues were experienced by me on the bent axle issue. A very easy diagnosis. Merely stretch a string from one end of the axle to the other. The string should sit flat on the axle from end to end. It if does not, you have a problem.
Swampfox
Posted: 21 Nov 2018 at 2:56pm |
Thanks. That is a simple way to check. When we get it back (probably before we leave the service department) I will ask if they checked for a bent axle (they are supposed to). If not, then I will have some string with me to do so.
CAhikers2x2
Posted: 21 Nov 2018 at 9:18pm |
I look forward to hear from you about what your RV techs find.
Thank you. Axle was mentioned by our RV tech when the tow truck dropped it off about 100 miles from home. Joanne |
Roger & Joanne
seafans
Senior Member Joined: 24 Nov 2017 Online Status: Offline Posts: 155 |
Posted: 28 Nov 2018 at 6:55pm |
CAhikers2x2 , have you checked the total axle weight of the trailer? Next time you are out run the trailer through a weight station that is closed so they don't git upset. Go very slowly over the scale. The axle weight should not be over about 3800-3900 to be safe. Depending on the empty weight. They only have about 800lbs. useful load.
Posted: 29 Nov 2018 at 9:20am |
As usual, YMMV.
Posted: 05 Dec 2018 at 11:23am |
The dealer said measurements were sent to LCI. I have not yet heard the results. I suspect a new axle may be in our 'Pod's future.
