Bearings and Wheel Problem-Twice |
Post Reply | Page 123 4> |
Billy Bob
Senior Member Joined: 11 Jun 2018 Location: Boulder City, N Online Status: Offline Posts: 103 |
Topic: Bearings and Wheel Problem-Twice Posted: 07 Jan 2019 at 11:38am |
Steve, pretty economical trailer for the mx costs vs usage !!!!
2019 RPOD 190
2017 Chev Colorado 4 X 4 Yellow Lab and English Springer Spaniel |
Posted: 07 Jan 2019 at 10:07am |
Sounds good.
Posted: 07 Jan 2019 at 9:26am |
Unfortunately, I was not able to determine it and I don't have the axle here to research further. I'll see if the dealer would be able to answer the questions.
Posted: 07 Jan 2019 at 4:11am |
StephenH, some forensics could be useful here. Were you or they able to determine where the axle bent? For example, was it the axle tube or the spindle attachment? If the tube, was the failure inboard or outboard of the frame attachment point? Which side?
Posted: 06 Jan 2019 at 4:30pm |
Update: No real answers as to what could have caused it to bend. The replacement axle was the same specifications as the original. Cost was $504.95 plus hardware kit $21.95 plus labor $250 plus tax, or $831.28 installed. Other items installed were two electric brake assemblies, a new hub, and new bearings and seals. Work also included repairing a water leak in the slide. From the way it was described, the work needed to seal it was extensive and included removing parts of the flange to get to the source and seal it. This ended up being a very expensive trip to the dealer to pick it up. However, given the amount of use we have given it, we have to expect that we would need to do maintenance. If I think of it as that we have towed it over 30,000 miles, it works out to about $.09/mile for what we paid. That does not include the new tires I have purchased or the cost of my modifications. We have spent quite a bit on the modifications, but they are not maintenance as such.
Vector1952
Groupie Joined: 28 Sep 2016 Location: RI Online Status: Offline Posts: 64 |
Posted: 02 Jan 2019 at 2:54pm |
I had a brake problem...when I used the bottom keter rail I damaged the wiring to the right side...only the left brake was being used...when braking trailer would jump jump and was very sensitive to the touch when braking...great wear on left wheel...replaced both left and right brakes with the brake kits sold at tractor supply company...cut the bottom mesh in two pieces...end of my problem...
Xxxx7
Posted: 01 Jan 2019 at 4:47pm |
I got the call that our R-Pod is ready to be picked up. I will see if I can find out more about the old axle and what could have bent it when I go to pick it up on Friday.
CAhikers2x2
Newbie Joined: 19 Jul 2017 Location: SF Bay Area, CA Online Status: Offline Posts: 12 |
Posted: 14 Dec 2018 at 2:09pm |
So sorry to hear that.
We did a long hesitation when we were buying our Pod new. We have used it once before, for a "crack" in one of the stove burners. The flame was trying to go below the burner. Yeah, that seemed scary. We combined with an exterior seal coming loose under the slide out (on the trailer wall section). Again, there was a $100. deductible...so pool the claims together if you can. |
Roger & Joanne
1 Camper Dog "Scout" 2015 RP 177 2016 Nissan Frontier 2001 Coleman Westlake |
Posted: 14 Dec 2018 at 1:08pm |
We don't have the extended warranty, so ours will be out-of-pocket.
CAhikers2x2
Posted: 14 Dec 2018 at 1:03pm |
We too are waiting for a new axle. Our extended warranty will cover "like for like" (less deductable and shipping). We hope this will be our resolve. Waiting for job completion and will post any new info when we pick up our Pod. Good luck to you and your Pod.
Joanne and Roger |
Roger & Joanne
