  New Posts New Posts RSS Feed: glowing LED
Topic Closedglowing LED
Pod People View Drop Down
Direct Link To This Post Topic: glowing LED
    Posted: 08 Aug 2018 at 7:52am
The exterior light on the front of our 179 will not completely turn off.  I noticed last night that it is "glowing" slightly-very dim.  I turned in on/off several times and it seems to work fine.  However, it never completely goes out.  it seems that about half of the LEDs continue to slightly glow even with the switch in the off position.  I never noticed this before, so I must assume that it is a recent change.
Anyone else seen this or have any ideas?
Thanks
Vann
Vann & Laura 2015 RPod 179
mcarter View Drop Down
Direct Link To This Post Posted: 08 Aug 2018 at 8:28am
I had that happen with an interior light. I ohmed out the switch and it was completely opening, letting the light stay on dimly. It worked in the ON position. I replaced the light. I could have replaced the switch, but with parts and labor it was more effective for me, to just replace the light.
Direct Link To This Post Posted: 08 Aug 2018 at 8:29am
That should have been "I ohmed switch, and it was NOT completely opening"
Direct Link To This Post Posted: 08 Aug 2018 at 8:30am
It takes almost no current to "light" an LED.. my guess is a bad switch also. I have noticed some LED lights glow for a short period, under a minute, even when completely disconnected from power.
