Page 12> |
![]() Posted: 01 Jul 2018 at 7:30am |
Taken off another forum for those that want the ability to tilt their TV mount.
"R-Pod TV mount from the factory comes with a 12" straight bar with the TV mounted at 90 degrees and no method of tilting. Harbor Freight this week with their July monthly sales pamphlet has a TV mount that tilts up to 15 degrees down. It is item Number: 64238. Last item, Page 16 of monthly ad. You use only the new TV mount and its head. Keep and use the original R-Pod 12" support to the wall. The new head and mount are interchangeable!! Remove the TV's 4 Philips head screws. Unbolt the large mounting head - 19 mm. Put Harbor Freight's mounting head on the end of the original arm: 3/16" allen wrench with 1/2"wrench. Place the flat washers in their original position so that it can be moved with some friction. Mount the Harbor Freight TV holder to the TV with the original Philips screws. Slip the TV and holder over the new mount and screw in the two side Philips support screws. Adjust everything to where it will move with some friction. |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6434 |
I wrote this up in my mods. One addition to the above is to take a small piece of 3/8" PEX tubing to use as a sleeve inside the end of the swing bar since the bolt for the new head and mount is smaller in diameter than the large bolt for the origninal non-tilting mounting plate. The 3/8" PEX tubing is just the right diameter inside for the new head's bolt and outside to fill the space so the head sits stable on the arm. See my mods for my write-up.
I did something similar with a mount I bought from Amazon. I don't remember the model, but the "head" was pretty much a direct fit onto the existing arm.
Alan
I remember that, but could not find the posts that discussed the tilt head to add onto. IIRC, that part was more expensive than the one from HF.
I just looked at the HF one. I definitely like the tilt mechanism much better; the one we have uses a knob at the back that's hard to get my fingers in to tighten and it's difficult to get seated correctly. At $15, it might be worth changing out our existing one. I'd probably 3D-print the bolt adapter.
I don't suppose the arm is a little longer than the factory mount. We have a 24" Samsung TV in our 179 now and I've had to rig up an extension. I'd like to eliminate the extension if I could. |
Alan
Happy Tripping ![]() Senior Member ![]() ![]() Joined: 27 May 2014 Online Status: Offline Posts: 473 |
Not wanting to be tiresome - This is a very nice product that I'd like to buy, but dang, it's made in China.
I wonder if just the head could be made to work with the factory mount's arm. |
Alan
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2710 |
We just got one of these. A couple of the mounting holes matched up, but a few of them didn't. NBD. The only issue was that the tilt was more up than down, so I reversed the mount so that it would tilt down more than up.
That is exactly what I described in my mods. The factory arm with the HF head and mounting plate.
Page 12> |
