  New Posts New Posts RSS Feed: 2018 vs. 2019
Topic Closed2018 vs. 2019 - Event Date: 20 Jun 2018
PilotPodder View Drop Down
Direct Link To This Post Calendar Event: 2018 vs. 2019
    Posted: 25 Jun 2018 at 8:14pm
This is what I use with a surge protector. Camco dogbone. Amazon link below but can get one at Walmart or Home Depot. To Mike’s point, I never run A/C or convection oven/microwave with it.
Camco Heavy Duty RV Dogbone Electrical Adapter with Innovative 180 Degree Bend Design and Easy PowerGrip Handle - https://www.amazon.com/dp/B000BUU5YA/ref=cm_sw_r_cp_api_EizmBbTRD1N2N
~PP
mcarter View Drop Down
Direct Link To This Post Posted: 25 Jun 2018 at 6:06pm
You need your power cord and an adapter that allows you to hook up said power cord to 110 extension cord (12 Gauge). Find at least a 15A plug and I recommend you do NOT run heavy, like AC. You can do Pod check outs etc. I do that to charge my battery when away from my 30A source I had installed.
cariefields View Drop Down
Direct Link To This Post Posted: 25 Jun 2018 at 5:44pm
This is likely silly question that will get lots of head shakes but I'm new to this - just brought R-POD 171 home today. Can I hook the electricity up to my house and if so, how?
Wood River Pod View Drop Down
Direct Link To This Post Posted: 24 Jun 2018 at 4:42pm
That's the wire to the screen/pendant.
Smith's in Hailey
Early 2017 179 HRE
Wood River Mods
Direct Link To This Post Posted: 24 Jun 2018 at 4:31pm
Jeff, what is the phone cord going into the box? Thermostat wire or something else?
Direct Link To This Post Posted: 24 Jun 2018 at 1:08pm
Thanks Jeff, it gives me a great look at where to put the unit in the 179. Very appreciated! ~PP
Direct Link To This Post Posted: 24 Jun 2018 at 12:24pm
Here you go.  Let me know if you have any questions.  I originally wanted to mount under the ottoman where 120 passes before heading across to power station.  Not enough slack in the line.  Wanted to keep splices to a minimum.  Sorry, second picture is sideways.
Thanks
Jeff
Smith's in Hailey
Early 2017 179 HRE
Wood River Mods
Direct Link To This Post Posted: 24 Jun 2018 at 12:12pm
I'll upload some pictures. I mounted it behind the power station to the left. Low on the wall in between the corner and the head door. I mounted a piece of pine that I could anchor into the studs. Then mounted the box on the pine. For me and my wires, it was easier to mount upside down. Does not hurt performance. Tight working conditions mounting, but the rest was easy.
Thanks
Jeff
Smith's in Hailey
Early 2017 179 HRE
Wood River Mods
Direct Link To This Post Posted: 24 Jun 2018 at 11:29am
Jeff, I’m very interested where you installed the unit in the 179 if you details. ~PP
Direct Link To This Post Posted: 24 Jun 2018 at 10:16am
I was torn between the portable and the hardwired.  I ultimately decided on the hardwired PI EMS-HW30C.  http://www.progressiveindustries.net/ems-hw30c  I have not regretted that decision in the 1.5 year I've had it.  It takes 30-45 min to install.  Then it's out of mind, out of sight, and always working.
We were camping in Sedona this spring.  The park filled up as we got closer to the weekend.  All these big rigs with all sorts electronics.   On Thursday night the PI shut down power to the pod.  Heard a bunch later that night all around us of problems people were having.  After a while, the EMS put us back online.  Disaster averted.
Highly recommend getting a step up from a surge protector.  Hardwired or portable is up to your preference.
Good luck.
Thanks
Jeff
Smith's in Hailey
Early 2017 179 HRE
Wood River Mods
