Dry Camping Travel with H20 - Event Date: 10 Jun 2018 - 01 Jul 2018 |
Post Reply | Page 12> |
Calendar Event: Dry Camping Travel with H20 Posted: 13 Jun 2018 at 11:46am |
I have never noticed any difference in the movement of the trailer (sway etc.) with changes in the amount of liquid in any of the tanks. Whether the tanks are full, empty, or in between, black, gray or "potable," it seems to make no difference in how the trailer tracks. I try to travel with empty tanks as a general rule to save on fuel and wear and tear on my TV, but that is not always possible.
Blender Bob
Groupie Joined: 11 Mar 2018 Location: Colorado Online Status: Offline Posts: 48 |
Posted: 13 Jun 2018 at 9:16am |
I found with our 178 with a full tank of fresh behind the axle -- a bit of sway is introduced, but only nearing 65mph. I also found that adding more weight(camping gear) to the front, increasing tongue weight by 100lb, helps reduce sway a lot. I have read insufficient tongue weight can cause sway, so manage that aspect of loading. all in all, adding 300lbs to 2800lbs of trailer weight is not noticeable in pulling with my T.V. I also use a classic blue water cube with the spigot replace by a 4 inch treaded pvc pipe as handy to add water I carry in the back of my truck, or pickup along the way.
Bob
2015 Chevy Colorado Z71 2018 178 R-pod Hood River Edition |
TheBum
Posted: 11 Jun 2018 at 12:12pm |
I've run our 179 with a full tank of water, pulling with a 2012 Highlander with a 3.5L V6 and haven't really noticed any difference vs. no water in the tank. The gray tank is behind the axle on the 179 and the fresh tank is furthest forward.
Alan
FrayAdjacent
Newbie Joined: 10 Jun 2018 Location: TX Online Status: Offline Posts: 31 |
Posted: 11 Jun 2018 at 4:01am |
I've heard it's best to fill it completely up, so the mass of water doesn't slosh around and cause sway. Dump grey and black before the return trip, and dump the remains of the fresh tank as well.
mjlrpod
Posted: 10 Jun 2018 at 3:18pm |
though not always, on several ocassions i've towed with full water tank. I noticed litle difference, I did get some sway on a rough uneven road, but I think it was more road condition than the water. My black and grey are both before the axle and always have something in them, that help reduce the weight of the fresh water just behind the axle.
Posted: 10 Jun 2018 at 1:53pm |
We always leave with a full tank of water in our 177. No problems with sway or climbing in the Rockies; we do however have a sway-bar link attached to negate this possibility. Have been doing it this way since 2011 pulling mainly with either a '08 or '13 Explorer
geewizard
Senior Member Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Posted: 10 Jun 2018 at 11:44am |
No worries, I do it all the time and over rough roads in MT, ID, and WA.
If you don't have a weight/sway control hitch, I suggest getting one. I have the Andersen hitch and it works great. https://andersenhitches.com/Catalog/andersen-nosway-weight-distribution-hitch.aspx |
ouRdogPod
Newbie Joined: 04 Jun 2018 Location: Virginia Online Status: Offline Posts: 9 |
Posted: 10 Jun 2018 at 10:40am |
I had a Tundra with the same engine. That truck was a work horse and towed like a dream!
RDOGPOD
2 Dogs and Us 2016 R-Pod 179 2015 Toyota Tundra |
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 10 Jun 2018 at 10:12am |
You should have no trouble with that much power. With my Ridgeline, I try to be more selective. For example, leaving tomorrow for a state park - called ahead and they have faucets I can use to fill up when I get there. Last two trips, no such luck so filled the tank before I left.
jonskipro
Newbie Joined: 22 Oct 2017 Location: California Online Status: Offline Posts: 7 |
Posted: 10 Jun 2018 at 10:04am |
Tars.
I'm pulling with Toyota tundra 5.7L V8 engine! Jon
Jon M
