Dry Camping Travel with H20
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11703
Printed Date: 11 Jul 2025 at 1:45pm
Topic: Dry Camping Travel with H20
Posted By: jonskipro
Subject: Dry Camping Travel with H20
Date Posted: 10 Jun 2018 at 9:35am
Can I travel with 36 gallons in water tank to a campground up in the mountains. About 50 miles?
Jon
Jon M
Posted By: Tars Tarkas
Date Posted: 10 Jun 2018 at 9:53am
Almost certainly, but it could depend on what you're pulling with, how steep the mountain roads are and maybe where your tank is located.  If the tank is behind the axle you could have sway issues.  That's 300 pounds of water.  On level ground you probably won't know it's there.
TT
FJ Cruiser
Date Posted: 10 Jun 2018 at 10:01am
Cool.....thanks for the info!
Jon M
Date Posted: 10 Jun 2018 at 10:04am
Tars.
 I'm pulling with Toyota tundra 5.7L V8 engine!
Jon
Jon M
Posted By: Ben Herman
Date Posted: 10 Jun 2018 at 10:12am
Originally posted by jonskipro
Tars.
Jon
You should have no trouble with that much power. With my Ridgeline, I try to be more selective. For example, leaving tomorrow for a state park - called ahead and they have faucets I can use to fill up when I get there. Last two trips, no such luck so filled the tank before I left.
Posted By: ouRdogPod
Date Posted: 10 Jun 2018 at 10:40am
I had a Tundra with the same engine. That truck was a work horse and towed like a dream!
RDOGPOD
2 Dogs and Us
2016 R-Pod 179
2015 Toyota Tundra
Posted By: geewizard
Date Posted: 10 Jun 2018 at 11:44am
No worries, I do it all the time and over rough roads in MT, ID, and WA.
If you don't have a weight/sway control hitch, I suggest getting one.  I have the Andersen hitch and it works great.
https://andersenhitches.com/Catalog/andersen-nosway-weight-distribution-hitch.aspx - https://andersenhitches.com/Catalog/andersen-nosway-weight-distribution-hitch.aspx
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Posted By: jato
Date Posted: 10 Jun 2018 at 1:53pm
We always leave with a full tank of water in our 177.  No problems with sway or climbing in the Rockies; we do however have a sway-bar link attached to negate this possibility.  Have been doing it this way since 2011 pulling mainly with either a '08 or '13 Explorer
Posted By: mjlrpod
Date Posted: 10 Jun 2018 at 3:18pm
though not always, on several ocassions i've towed with full water tank. I noticed litle difference, I did get some sway on a rough uneven road, but I think it was more road condition than the water. My black and grey are both before the axle and always have something in them, that help reduce the weight of the fresh water just behind the axle.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted By: FrayAdjacent
Date Posted: 11 Jun 2018 at 4:01am
I've heard it's best to fill it completely up, so the mass of water doesn't slosh around and cause sway. Dump grey and black before the return trip, and dump the remains of the fresh tank as well.
Posted By: TheBum
Date Posted: 11 Jun 2018 at 12:12pm
I've run our 179 with a full tank of water, pulling with a 2012 Highlander with a 3.5L V6 and haven't really noticed any difference vs. no water in the tank. The gray tank is behind the axle on the 179 and the fresh tank is furthest forward.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Posted By: Blender Bob
Date Posted: 13 Jun 2018 at 9:16am
I found with our 178 with a full tank of fresh behind the axle -- a bit of sway is introduced, but only nearing 65mph. I also found that adding more weight(camping gear) to the front, increasing tongue weight by 100lb, helps reduce sway a lot. I have read insufficient tongue weight can cause sway, so manage that aspect of loading.  all in all, adding 300lbs to 2800lbs of trailer weight is not noticeable in pulling with my T.V.
I also use a classic blue water cube with the spigot replace by a 4 inch treaded pvc pipe as handy to add water I carry in the back of my truck, or pickup along the way.
Bob
2015 Chevy Colorado Z71
2018 178 R-pod Hood River Edition
Posted By: lostagain
Date Posted: 13 Jun 2018 at 11:46am
I have never noticed any difference in the movement of the trailer (sway etc.) with changes in the amount of liquid in any of the tanks.  Whether the tanks are full, empty, or in between, black, gray or "potable," it seems to make no difference in how the trailer tracks.  I try to travel with empty tanks as a general rule to save on fuel and wear and tear on my TV, but that is not always possible.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
