Generator |
Post Reply | Page 123 7> |
Topic: Generator Posted: 07 Jul 2018 at 7:57am |
Welcome! This forum has been a wealth of information and ideas. In turn, as I have benefitted from the experience of others, I have tried to share some of my ideas. Some of my mods are not original with me but some are. In any case, I hope you can benefit and in turn contribute ideas of your own.
Posted: 07 Jul 2018 at 7:46am |
Welcome Aboard.
Vernonymous
Newbie Joined: 05 May 2018 Location: WA Online Status: Offline Posts: 3 |
Posted: 06 Jul 2018 at 10:43pm |
mcarter, I'm new to the site and now that I've gone back and read the whole thread, I'm up to speed! Boy, you guys who've been down the path a little farther are going to be a great help to me!
Posted: 06 Jul 2018 at 3:17pm |
Vernonymous, Which genset and which problem?
Posted: 06 Jul 2018 at 2:40pm |
If it is the Micro-Air Easy Start, then the web site is: Don't forget the discount code FORESTRIVER The unit is installed inside the unit on top of the R-Pod. There is a good guide on the web site for installing in the Penguin II unit.
Vernonymous
Posted: 06 Jul 2018 at 1:43pm |
This is interesting. I'm running the same generator and encountering the same problem. Would you steer me to a website to learn more about these units? Also, how, where did you install it?
Posted: 27 Jun 2018 at 5:15pm |
+1 SH, very happy with a light weight single genset, I don't want a genset that weighs a 100 pounds, I want an emergency power source that functions to keep me rolling and working. I can charge my battery, run the micro and the AC and pick it up and carry it. Without adding significantly to weight. I have a Pod to have some constraint otherwise I would have kept my class C.
lostagain
Posted: 27 Jun 2018 at 11:58am |
We got the Champion inverter generator duel fuel 3100/2800W. It's just under 100 lbs and has very useful handles, so I can lift it into the back of our truck with out a problem. Seems to run the AC comfortably on propane, but starting the AC is always challenging, especially after it's been running and needs to restart shortly after turning off. It's a just about as quiet as the Honda and Yamaha, but much, much less expensive and comes with a 3 year wheel to plug warranty.
Posted: 27 Jun 2018 at 10:22am |
I had been looking at the Predator 3500 generator. When considering the cost of the larger generator (about $700) plus the additional size and weight and comparing with the Generac iX2000 that we already have, the Micro-Air Easy Start looked a lot more attractive, especially with the discount. Plus, I can lift the Generac iX2000 up to the Stromberg-Carlson Trailer Tray. I would not be able to do the same with the larger, heavier Predator or any other 3500 Watt generator.
lostagain
Posted: 27 Jun 2018 at 10:04am |
Thanks, StephenH.
@ $259 + tax, lic, & doc fee, it looks like a pretty good deal. Soft start systems are the way to go when ever you can get them to put on things using an electric motor and needing a lot of "umpf" in the start process. We use them extensively in the elevator industry, especially for hydraulic jack pumps. They really extend the life of the equipment.
