  New Posts New Posts RSS Feed: better antenna?
Topic Closedbetter antenna?
sean p View Drop Down
Direct Link To This Post Topic: better antenna?
    Posted: 28 May 2018 at 6:58am
Is there a better antenna i can get for my 179. The radio im sure could pick up better reception with a diffrent antenna. Do the batwing antennas pick up more radio reception. I get over 50 hd channels at home with the current antenna.
2016 179pod--BETTY
2010 nissan frontier
Sean and Doug
Butchie the morkie
touring the west
Pod People View Drop Down
Direct Link To This Post Posted: 28 May 2018 at 8:19am
are you engaging the antenna booster? It is the small button on the same faceplate as the antenna input cable.
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 28 May 2018 at 8:31am
Well good heavens. I'll give it a try. was never aware of its function,thought it was for cable imput. Thanks
2016 179pod--BETTY
Sean and Doug
Butchie the morkie
touring the west
crankster78 View Drop Down
Direct Link To This Post Posted: 28 May 2018 at 9:00am
Greetings
I put a bookshelf Stereo system in my 179.  I attached a 3 foot post to the hitch area, have 3 sections of light tv mast and put a omidirectional   FM antenna on top.  I use a piece of coax to plug it in to the outside plug.  It sounds and receives great.  It takes about 5 minutes to set up and take down.
Crankster78
Crankster 78 R-179 2015
mjlrpod View Drop Down
Direct Link To This Post Posted: 28 May 2018 at 5:34pm
I don't know why you have to turn on the antennae booster separately. You almost CANNOT either watch t.v. or listen to the radio without turning on the booster switch, yet, it's a whole different button. THEN you have to remember to shut it OFF or kill your battery. What do I know.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
ZuBrew View Drop Down
Direct Link To This Post Posted: 29 May 2018 at 9:01am
Originally posted by crankster78
Greetings
Crankster78
Crankster,
Could you send more info and some pictures for this antenna setup you have? We just camped about 20 miles from our local city and I couldn't pick up any channels. Thanks.
2017 Chevy Silverado 1500 4X4
2018 R-Pod 189
2013 Yamaha FJR 1300A
Direct Link To This Post Posted: 29 May 2018 at 9:24am
Greetings
Go to Amazon,  enter outdoor FM antennas,  Look for a omnidirectional. If I remember, they are about $40.  Get some cheap 5 foot sections of tv mast, a piece of 3/4 inch square tubing and a couple of clamps long enough to clamp the tubing to the hitch frame..  Get a piece of tv coax long enough to reach the plug on the side of the cabin. I also use an external amp.  You could also install a small tv antenna in place of the FM.  I use the mounted antenna for what little TV I watch.  If you are going to use the installed radio, you may need to switch the coax to that unit by pulling it out { 4 screws)
I don't use it except when on battery.
Crankster78
TheBum View Drop Down
Direct Link To This Post Posted: 29 May 2018 at 10:50am
If you go to a campground that has cable hookups and you want to one, you have to turn off the booster.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Tomcheryl View Drop Down
Direct Link To This Post Posted: 29 May 2018 at 3:23pm
BOOSTER???? what?? ok That would explain the crappy radio reception!! I just happen to have the pod in out front ..... I'm going to look for it now. Is it the face plate with the cable and satellite ? if it is, it looks like it has always been on??!! should i turn it off when not in use? our battery seems to drop quickly, I'm changing to two 6 v because of it.
My husband and I are super newbies ,still learning. I'm all about the mods!!
thanks Cheryl
Life is short,it’s time to roll
Direct Link To This Post Posted: 29 May 2018 at 3:26pm
You're probably better off with a disconnect switch on your battery. There are a number of parasitic drains on the battery from various electronics; a disconnect switch will eliminate all of them.
Alan
Three cats
