cord ring |
hogone
Senior Member Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1042 |
Topic: cord ring Posted: 22 May 2018 at 5:45am |
anybody have there electric cord nut(ring) that screws on the camper electric input crack/break? i see you can purchase a new one but it sounds there hard to get on. I'm not sure that made sense!! hopefully so though. hogone
Jon & Pam
Posted: 22 May 2018 at 7:52am |
Threaded locking ring on female end of power cable? I never had one break. I also found new ones to purchase but no install info.
Pod People
Senior Member Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1066 |
Posted: 22 May 2018 at 8:31am |
ours cracked and I repaired it with super glue. still holding ok. I think it cracked from either twisting it too tight on the pod or dropping the cord on the ground. I try not to do either of these any more. Vann
TheBum
Posted: 22 May 2018 at 10:47am |
It probably broke from being cross-threaded, which is easy to do. The trick I've discovered is to start by screwing it counterclockwise until the thread seats and then screw it clockwise to secure it.
Alan
Posted: 22 May 2018 at 3:33pm |
And to make sure it is fully inserted before tightening. Just like any coupler.
Posted: 23 May 2018 at 1:39am |
I accidentally ran over mine and broke it. I purchased a new ring and used hot water to soften the plastic flange so that I could work the ring over it. Then I fastened the plug to the coupler ring that came with the new ring (cheaper to purchase the set than to purchase just the ring) to flatten out the flange so that it would be in the proper shape as it cooled. I'm taking extra care not to run over it again.
hogone
Posted: 24 May 2018 at 5:34am |
super glue was the trick!!!!!! hogone
Jon & Pam
