grizwalsh
Topic: sewer Posted: 21 May 2018 at 11:40am |
Just went on our first shakedown cruise and I have a few questions for you veterans--We have a sewer hook-up and I just want to know how it diverts from the holding tank--is there a valve you switch?---also we don't get very good reception from our radio--anyone else have that problem--Thanks
grizwalsh
TheBum
Posted: 21 May 2018 at 12:59pm |
When you look under the Pod, you should see the dump valve with a large handle protruding to the side. Simply pull out on that handle to initiate the flow out of the holding tank and into the sewer. Push it back in when done.
As for the radio, take a look at the inside wall plate where the TV cable connectors are. You should see a little button on it. If the LED indicator next to it is off, then press the button to turn it on. This activates the signal booster.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Tars Tarkas
Posted: 21 May 2018 at 6:04pm |
Originally posted by grizwalsh
Just went on our first shakedown cruise and I have a few questions for you veterans--We have a sewer hook-up and I just want to know how it diverts from the holding tank--is there a valve you switch? |
I'm not sure I understand what you're asking so I'll give a long explanation. There are two holding tanks on pods for waste; a black water tank (for the toilet) and a grey water tank for the sink and shower. Each tank has it's own outlet on the street side of the pod, probably fore and aft of the axle. Take the cap off, one at a time, black tank first, hook up your sewer hose, put the other end in the receptacle for the waste, pull the T-handle out and the sewage will come gushing out. When everything is out of the black tank, close the valve, take the hose off and put the cap back on. Move to the grey tank outlet and repeat. Rinse your hose and any mess you may have made at the dump station. TT
FJ Cruiser
Posted: 21 May 2018 at 6:08pm |
+1 - not sure I understand either.
grizwalsh
Posted: 21 May 2018 at 6:24pm |
Thanks for the info---I was doing it right--just got a little confused--How come this happens?--I'm only 70
grizwalsh
Posted: 21 May 2018 at 6:29pm |
I wish I could answer that. Sometimes I'm confused to my friend.
TheBum
Posted: 22 May 2018 at 10:51am |
BTW, the signal booster needs to be off if you're connecting to campground cable TV.
Alan
Three cats
grizwalsh
Posted: 22 May 2018 at 12:15pm |
Thank you Sir.
grizwalsh
grizwalsh
Posted: 23 May 2018 at 10:33am |
Hi--me again--the tv is on the wall just inside the door and I can't see any button near the connectors--the radio is on the wall over the bed--I have a r177--would this make a difference?
grizwalsh
TheBum
Posted: 23 May 2018 at 11:09am |
The model of R-Pod shouldn't matter. How old is the 177? Did you buy it new?
Alan
Three cats
