178 Ultimate Over the Bed Shelf |
Post Reply | Page 12> |
Author | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
supra8311
Newbie Joined: 19 Sep 2015 Location: Arvada, CO Online Status: Offline Posts: 3 |
Topic: 178 Ultimate Over the Bed Shelf Posted: 29 Apr 2018 at 9:22pm |
We needed a shelf over the bed. Unfortunately, I could not match out trim color with the “Lowe’s Shelf
Mod“. So I made a torsion box style shelf and matched the stain. In case it’ll anyone has the same problem, here are some picture of what I did. It is very sturdy. This is the inside. Ribs made of 3/4" plywood. Top and bottom are 1/2 plywood. Here it is installed Andre |
lostagain
Posted: 29 Apr 2018 at 10:27pm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Looks really nice.
Ghosthawk
Senior Member Joined: 01 Apr 2018 Location: Fargo ND Online Status: Offline Posts: 128 |
Posted: 30 Apr 2018 at 6:43am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Awesome!
How did you attach it? |
Posted: 30 Apr 2018 at 9:34am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
How heavy is it?
supra8311
Posted: 30 Apr 2018 at 10:44pm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
I used brackets to attache the shelf to the walls. There was a stud running horizontally above the window. I was able to get one screw on each bracket in a stud. There was a stud running horizontally above the window. |
supra8311
Posted: 30 Apr 2018 at 10:58pm | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Good question. It feels like a hollow core door. I didn't weight it and there is no way I'm taking it back out I calculated the plywood weight and got 22.1 lbs. I think it weighs 25 lbs with the wood trim, glue, and nails.
Posted: 01 May 2018 at 7:45am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Thanks. One more question: How did you match the stain? Would you please list the formula? I thought I had seen it before, but couldn't find it. I got close on my last attempt, but it still was not right.
jimandclare
Groupie Joined: 13 Apr 2016 Location: Erie, MI Online Status: Offline Posts: 96 |
Posted: 01 May 2018 at 8:37am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Here is the Sherwin-Williams formula for the rpod dark brown colored wood. Will need to build up 3 to 4 coats to get results that match.
Jim & Clare
2016 R-pod 178 2014 Ford Edge |
Posted: 01 May 2018 at 8:41am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Thanks. I saved a copy of the image this time.
Old Surfer
Newbie Joined: 14 Mar 2015 Location: Paso Robles, Ca Online Status: Offline Posts: 31 |
Posted: 22 Feb 2019 at 11:47am | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Thanks for the formula. I took a draw front to Lows to get a match and they didn't come closed.
Rick and Melanie
2008 Tundra CrewMax 4-Wheel Drive 2015 R-179 Surfer |
