  New Posts New Posts RSS Feed: Dome Set-Up. The Definitive List
Topic ClosedDome Set-Up. The Definitive List
Tusten Traveler View Drop Down
Direct Link To This Post Topic: Dome Set-Up. The Definitive List
    Posted: 07 Mar 2010 at 12:29pm
Can someone who has done it several times and has a good system please give me a list in order of how to set up the R-Dome? We want to try it, but have forgotten everything we saw at Couch's 7 months ago and it has remained in the box. Every "tip" will be appreciated- even where to place items as they come out of the box.
Thank you!
John and Linda
One 14 lb Cockapoo
2010 RPod 174
HuronSailor View Drop Down
Direct Link To This Post Posted: 07 Mar 2010 at 6:30pm
1. Remove instruction booklet from the bag, grasp it firmly by one corner, and throw it as far away as you possibly can. It's worthlessly generic and seems to have instructions for everything from boiling water to brain surgery. Once you heave that puppy, it's easier if you have two people for the actual setup process. Here goes:
2. Unroll the dome, make sure it's right side out (screen coverings go outside), then slide the attached awning rope through the track over the rPod door. One can push, and one can pull. If you sand/lube the track up, and make sure all the screws are tight before hand so you don't snag a screw head (hello, Forest River quality control) it actually slides in pretty easily, and one person can just push it through.
3. With a healthy amount of fear, and possibly protective eyewear, begin assembling the very long aluminum arch pole segment by segment as you push it into the slot in the front wall of the dome. Do not attempt to pull it through. If you pull on it, it will come apart somewhere inside the dome. Do not ask how I know this. Don't try to assemble it into its finished length before you start inserting it into the dome, because it will come apart before you get done. Don't ask how I know this.  The second person can help by smoothing out wrinkles and kinks ahead of the advancing arch pole. Keep pushing it through until you have equal amounts of pole sticking out each end.
4. Bend the pole into an arch and temporarily plant the ends in the ground. Connect the threshold strap together to keep the ends of the arch pole from sproinging apart. You can fine tune this later. Have your helper stand in front of the dome,  holding the side support straps to keep the front wall of the dome from tipping over.
5. Go inside with the telescoping roof poles. Insert the ball of the center pole into the socket (you may need a short stool like I do), extend the pole, and clip the other end onto the aluminum arch pole through the slot provided in the dome. Extend the pole just enough to take the wrinkles out of the roof, then lock it. Make sure the locking handle itself doesn't rub on the inside of the roof, because if there's any breeze at all making the dome flutter, you'll have yourself a hole in the roof in a surprisingly short time. Don't ask how I know this. Repeat for the two end roof poles. At this point your helper doesn't need to hold the straps anymore, the dome will stand on its own.
6. Try opening the pod's door. You may want to slide the whole shootin' match within the track toward the front of the pod a wee bit, so the door can open all the way and clear the front roof pole. Engineering change needed here, I'd say.
7. Come outside, zip the doors closed. Make any minor adjustments to the position of the arch pole ends, moving them closer to or farther away from the rpod so the dome just comes up flush against the pod itself. I like to  make mine look nice and even and pretty.
8. Make any needed adjustments to the length of the threshold strap. The key is to keep the arch in the pole tight enough that you don't have any pressure trying to pull the big door zipper apart. Run the side straps out and stake them down, with very very little tension. Too much tension here will also tend to spread the door zipper apart, making it tough to open and close when you get near the top of the zipper's travel.
9. Go around inside and stake the loops down, with the gray rain runoff flaps all sticking outside.  I usually put a stake over the threshold strap near the base of each end of the arch pole, and one over the strap right in the middle. This minimizes the chance you'll snag the strap with your toe, which can make you spill your beer. Don't ask how I know this.
10. The first time you slide the bug screen in the bottom track, you'll probably want to make a simple horizontal slit for the rpod step to poke through, and a vertical slit where the rpod axle is.
gizeh View Drop Down
Direct Link To This Post Posted: 07 Mar 2010 at 7:08pm
We thank Tusten Traveler for asking the question, and HuronSailor for the MOST helpful (and humorous!) reply.   We will print your instructions and take them with us on our maiden voyage.  We very much appreciate the time and thought you took to write such organized directions.
Tunsten T - We are also, "John and Linda!"
HuronSailor - Linda is also a HAM (KG6FOT) not operating lately
John and Linda
175 r-pod, Ford F-250
'89 Alaskan camper
'62 VW Bug
Direct Link To This Post Posted: 07 Mar 2010 at 11:00pm
Wow Huron!!! Can't thank you enough Hug....if we can't figure it out from your incredible list, we don't deserve to call ourselves campers!  And clearly a sense of humor helps the process...
Thanks again....we'll let you know how it goes when we try it in the next few weeks.
John and Linda
One 14 lb Cockapoo
2010 RPod 174
Outbound View Drop Down
Direct Link To This Post Posted: 08 Mar 2010 at 11:35am
Great Instructions, HuronSailor!
I found that two verticle slits, one on either side of the step so that the middle piece fits down behind the step, works very well.
Direct Link To This Post Posted: 08 Mar 2010 at 11:50am
That actually sounds like it might work better than the horizontal slit I used.
Direct Link To This Post Posted: 08 Mar 2010 at 4:02pm
The first time or two I would add "open six pack of beer".  And "be prepared to flip the canopy over and reinsert into the c-channel 2 or 3 times.  In the dark."
Direct Link To This Post Posted: 08 Mar 2010 at 6:46pm
Aw, shucks, it was nothin', really. I had some purty good English teachers.
As a freshman in English 101 I was assigned to write a booklet called "The Comprehensive Guide To Setting The Table For Tea." My professor's comment after reading the booklet was simply, "Comprehensive, indeed."
sylviablue View Drop Down
Direct Link To This Post Posted: 09 Mar 2010 at 7:22pm
Big smile  You are too funny.
Hey, setting up the r-dome takes ten minutes guys.  It's not rocket science as we used to say.
four peas
Direct Link To This Post Posted: 09 Mar 2010 at 7:49pm
Still easier with that six pack!
