  New Posts New Posts RSS Feed: Fridge On Propane - Again.
Topic ClosedFridge On Propane - Again.
Direct Link To This Post Topic: Fridge On Propane - Again.
    Posted: 13 Apr 2018 at 2:14pm
Great to hear.. Smile  Cold beer rocks.
shicks View Drop Down
Direct Link To This Post Posted: 27 Nov 2018 at 7:42am
Another update:  The 120vac stopped working for the fridge and the burner assembly started rusting making it difficult to keep clean.  That meant a $400 control board and $100+ for the burner assembly.  So I decided to chuck it and get a new RM8505.   This is same size as the default RM8501 but has the auto change over from 120vac to Propane (and back).  The burner assembly is different, hopefully better.  Expensive replacement but I'm happy with it so far.
RP 2014 178/Grand Cherokee/E2 WDH/Prodigy P3
Mods: Solar, lowes shelves, sink-out, dual batts/propane, steps, door window, EMS, glass stove top, tires, Microair EasyStart... it doesn't seem to end.
Direct Link To This Post Posted: 27 Nov 2018 at 7:55am
Did you do the swap out yourself? Dealing with getting fridges in and out of the doorway can be an issue on many rigs..
Direct Link To This Post Posted: 27 Nov 2018 at 8:15am
I swapped it out myself.   It fits through the door easily (with a helper), with fridge door out so can continue into the opening without turning it (backed the fridge into the camper to the opening).  I added insulation to the side and top walls of the opening.
Challenges:
1. A trim on the bottom rear of the opening helps keep fridge steady but getting the rear "legs/pads" of the fridge over it is tricky.
2. Figuring out how to grab it while pushing into place is important.  I broke a brace that supports the control facia (don't grab it).  Luckily the old fridge had the same brace and I swapped it out.
3. the seal that prevents backdraft doesn't seal very well after install.  Used duct tape to seal it up behind the fridge.
4. the install screw holes on the door edge were not drilled out.  Had to pull the fridge out over that trim piece again to drill them.
Nice not having to remember to switch the power.  And not worrying when power or gen go out.
