  New Posts New Posts RSS Feed: worn tires.
Topic Closedworn tires.
spydie View Drop Down
Direct Link To This Post Topic: worn tires.
    Posted: 24 Aug 2017 at 11:15pm
Yes, Radials are used on travel trailers.  several or maybe many companies brag about using them including the R-pod (although I have no idea when they started using them).  My 2018 model has nitrogen filled Radial tires.  you can check Forest River's R-pod site and see them brag about it.
2018 R-pod 176
2017 RAM 1500 5.7L Hemi
Wood River Pod View Drop Down
Direct Link To This Post Posted: 24 Aug 2017 at 10:34pm
Sean, are you replacing with 235's?  Which LT tire are you going with?  Was always told not to put passenger tires on a trailer, but numerous have said its ok as long as you get the right kind.  I guess the right kind have higher ply and stiffer sidewall.  So if we want to keep the 235's, LT is the way to go.  As I mentioned before, there are no 235 75 15 replacement trailer tires.  Why would FR put a tire on our pods that no replacement exists?  Frustrating.
Good Luck!
Thanks
Jeff
Smith's in Hailey
Early 2017 179 HRE
Wood River Mods
sean p View Drop Down
Direct Link To This Post Posted: 24 Aug 2017 at 6:01pm
Worn tire update, So my axel is is off its mark by 7/8" on the right side. They specialize in axel repair and are going to make the correction. and they are putting 2 new light duty truck tires on that will be just fine. I can go at higher speeds but not much traction in dirt situations. That's ok as i'll be spending most time on highways. Of course this is to the tune of 500.00. I'm asking what is the likely hood that either FR or Lippert will reimburse me for my charges as the trailer and tires have less than 7000 miles on them and the repair shop says the axel bent ate my tires up. Any imput would be great. Sean
2016 179pod--BETTY
2010 nissan frontier
Sean and Doug
Butchie the morkie
touring the west
Direct Link To This Post Posted: 20 Aug 2017 at 11:48am
Omg, thanks guys, lots of info. i have axel apt. tuesday, i will deffinatly be on with results. I wonder if i should contact forest river.
2016 179pod--BETTY
Sean and Doug
Butchie the morkie
touring the west
mjlrpod View Drop Down
Direct Link To This Post Posted: 20 Aug 2017 at 11:43am
Lots of opposites of what i've been told here. I've been told the following
1) Radials are good trailer tires because they dont heat up as much as bias tires.
2) NEVER use auto tires on a trailer. Trailer tires are rated to hold much more weight.
3) My Carlisles are reted for 4200 pounds, at 81 m.p.h. @ 65 p.s.i.
**** 4200 pounds for both tires together
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Blue Highways View Drop Down
Direct Link To This Post Posted: 20 Aug 2017 at 10:42am
Thanks, John, I had no clue my factory Westlakes might not be actual radials; (Could be true, I'll investigate)....in fact I didn't think non-radials were manufactured anymore for general road use, based on the old "sudden blow-out" reputations from the bias plys of my father's days.
But I do want a tire that can handle 70+ mpg with a load rating approaching 5000#s, because sometimes you have to run that periodically with your trailer to get out of a dangerous tangle of jockeying aggressive 18-wheelers. (Which is not the way mature, experienced truckers with good safety records drive.)
I'll put some thought to side wall flex: I do notice when the very visible R-pod tires hit a dip in the road, they "sponge-out" clearly, softening the shock up through the trailer chassis. That may be the clue to what makes a trailer tire construction different. Hmmmm.
Thanks for the thoughts, john!
john in idaho View Drop Down
Direct Link To This Post Posted: 20 Aug 2017 at 10:20am
It is my understanding that one should not use radial tires on a trailer.  Too much sidewall flex.  But ask at the tire store.  Also = most trailer tires are not rated for more than 60 or 65 mph.  One certainly sees them going much faster , though.
Direct Link To This Post Posted: 20 Aug 2017 at 9:48am
Sean: Re: worn tires. I think you may have a mis-aligned axle, or extremely non-conforming axle which is worth investigating this week, and here's why.
We have almost 10,000 miles on our 17 HRE with Westlake 235-785-15s that were filled with nitrogen. Same tire Wood River Pod has. This Unit was purchased while we were living in Alaska, and we brought it down the Alcan Highway, Cassiar Highway, into WA then ran the entire Oregon Coast; back through Crater Lake, Idaho, and all the way out to Western North Carolina. Since then we have explored the Blue Ridge Parkway up into Virginia and back.
Roads starting from Alaska, Yukon Territories & BC ranged from rough frost-heaved pavement, very coarse pavement, sharp (windshield cracking) gravel construction zones, smooth pavement, curves, inclines all the way up to smooth higher-speed Interstate running often at higher summer temperatures.
We never had a flat, never had to add any significant air, the deep Westlake tire lugs are not excessively worn, and there is totally even wear across the crown of the tires. I think it is a "Lippert" trailer axle, but I can check. Not sure if it is a 3500# or 4000# that HRE Pods come stock with, or whether there was a vendor change in who supplies the axles to FR. We did not add the FR optional lifting blocks to the axle.
Since you are having such extreme outside edge wear, you fully deserve to have this finally corrected. If they find the axle is defective and can't be corrected by shims shackles & adjustments, I'd consider making lemonade out of lemons by jumping a step up in axle durability rating, maybe put an inch or 2 of lift on it, and thus upgrade your way out of the problem ending with something much better that must be installed to your tire wear satisfaction.
Is this reasonable? I am truly sorry you have this $$$ hassle to deal with. It's as if your axle has an arch in it; high in the center & curving down beyond spec as you move out to each wheel hub. If you never remember high-centering over a big nasty boulder, this must be a defective axle from its maker, if it cannot be adjusted back into specifications.
I'm really curious as to what you find out on this. I hope things get solved so you can relax. Please let the forum know what you learn !
---brad
2 Questions for Jeff (Wood River Pod) because I don't know a huge amount about tires, beyond brand research:
1) Are the equivalent Westlake trailer 235-75-15 size tires really hard to find? Even at Hailey's Les Scwab?
Reason I ask is that I am old enough to remember almost EVERY car had that size-range back in the day. (I do get that any 14" tire is a 'tough find' for classic cars that weren't upgraded at least to 15s). But with so many muscle and classic cars being collected, would not a top-quality radial vehicle tire do an even better job than a trailer tire for our Pods?
I'm asking this out of ignorance, because I must have some pre-conceptions that must be wrong and wanted to get your knowledge on the subject, even though I don't need to replace the Pods tires until perhaps 2019 season.
2) You mentioned finding that "trailer tires" that size are hard to find. Wouldn't a "vehicle tire" be equal to, or stronger construction than a trailer tire? I always thought trailer tires had less quality, because they don't have to steer or part water for hydroplaning, etc. and have more stringent standards for manufacturer's standards of ride & handling. Do trailer tires have special characteristics that are missed by vehicle tires?
Really curious / want to learn from everybody
--brad
Direct Link To This Post Posted: 19 Aug 2017 at 5:44pm
+1
Direct Link To This Post Posted: 19 Aug 2017 at 4:43pm
I use Carlisle 14 inch radial trail HD load range D tires. Great tires, track excellent, even in the downpour i drove in yesterday. Cheaper than the GY endurance too.
2020 R-pod 195
I'll be rpodding
