  New Posts New Posts RSS Feed: wall thickness?
Topic Closedwall thickness?
spydie View Drop Down
Direct Link To This Post Topic: wall thickness?
    Posted: 30 Jul 2017 at 12:37pm
I'm getting ready to research a good window to install in the bunk area of my new 176.  Does anyone know offhand what the actual sidewall thickness is?  I think I read someplace that's 1" thick but I can't find that post and I want to be sure.
2018 R-pod 176
2017 RAM 1500 5.7L Hemi
Q7-retired View Drop Down
Direct Link To This Post Posted: 02 Aug 2017 at 3:42pm
I just drilled a hole in my ceiling (for an antenna mount) and found the ceiling was just shy of 1.75" thick.  Presumably, the walls are the same.
Best regards, Jim
2015-RP178
TV 2015 Audi Q7 TDI and 2017 Ford F150
At home in "Our Pod"
Direct Link To This Post Posted: 02 Aug 2017 at 3:47pm
Thanks, but actually it's been confirmed the walls are 1 5/16" thick.
2018 R-pod 176
Direct Link To This Post Posted: 02 Aug 2017 at 8:24pm
The ceiling is a whole different story. The flat part has a double ceiling. Aluminum frame on the bottom and wood on top. The wood framing for the roof goes from one end to the other. there is foam in the aluminum part and fibre glass in the rest of the ceiling.
