  New Posts New Posts RSS Feed: Maiden Voyage
Topic ClosedMaiden Voyage
Joe-n-Terri View Drop Down
Direct Link To This Post Topic: Maiden Voyage
    Posted: 28 Mar 2015 at 12:12am
No I haven't but I have not pursued it hard. Haven't had a chance to road test the Town and Country yet between work, getting the garden in and trying to build a patio. Starting to get people knocking on the door wanting to look at the 179, I don't mind showing it, just wish I was doing it in a campground.
Joe & Terri
2015 179
2015 Ram 1500 crew cab/ eco diesel
2005 Ram 1500/ Tekonsha Controller
Lovestarved Pom/Demanding Chihuahua
Direct Link To This Post Posted: 28 Mar 2015 at 9:09am
Originally posted by johnmaci
Did you ever get an answer on the deflation of the air bags?
I just purchased a set of firestone air bags that fit inside the coils but have not yet installed them.
Even with the WDH, the weight of the stuff I put in the back of my Pathfinder still bring the headlights up enough for oncoming vehicles to flash me.
Your WDH is not adjusted right. Simple as that.
With no camper hooked up, on flat level ground, measure the distance from the ground to the bottom lip of your front and rear wheel openings. Now hookup the trailer and load the truck with the WDH installed. Now adjust the tension on your WDH, either by changing chain links or moving the perch, (I don't know what style you have) until the wheel arch measurement is the same as it was when you were not hooked up and loaded. Done.
One note.. if you are seeing this much "squat" in your truck, make sure your total rig weight is under the GVWR rating for your truck.
johnmaci View Drop Down
Direct Link To This Post Posted: 28 Mar 2015 at 4:06pm
Thank you for that information.
I know that I am under the GVWR, but since I load most of my clothes, food, toiletries, gear, etc. in the back of the SUV to keep the TT light, I am thinking that may increase the tongue weight over the 500 lbs limit.....
The dealer installed the WDH and I have not had an opportunity to take any measurements since (due to my HOA rules), I have to store my TT at a storage lot; And the lot is gravel :(
Direct Link To This Post Posted: 28 Mar 2015 at 4:43pm
If the dealer installed it, it isn't installed right.  Often the problem is because they do it when you buy it so the pod is still empty.  It must be loaded up like you are ready for a camping trip (including water in the fresh water tank if you usually travel like that, battery, propane).  Some go as far as having their family sit in the truck, or adding weight to simulate them.
This is the most comprehensive instructional on how to set up a WDH I've ever seen.  I used it to tweak my current WDH.  http://www.rv.net/FORUM/index.cfm/fuseaction/thread/tid/17730894.cfm
Pod People View Drop Down
Direct Link To This Post Posted: 28 Mar 2015 at 6:30pm
I would add to Tech n Trek 's post that another important thing to check regarding the weight distribution set up is your tongue weight.  I loaded the trailer just as if we were heading out. I set up my wdh  and measured  and changed it and measured again and changed it  until I thought it was right.  Then I went to our local landfill and weighed ervrytything only to find out that my tongue weight was way too low.  so while at the weight station, I repacked the trailer, moving more weight in front of the axle and then reweighed it.  this time, the tongue weight was good, but the measurements showed too much weight on the rear.  After readjusting the wdh, it now tows beautifully with no sway and no rear sag.
Correctly packing the  rpod has just as much or more to do with sway control as the wdh does .  Its really important to have 12-15% tongue weight in order to tow properly.  Too little or too much can create real problems .
Vann Evans
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 28 Mar 2015 at 8:36pm
Good point!
Ontheedge View Drop Down
Direct Link To This Post Posted: 07 May 2015 at 9:48pm
I have a blue ox sway pro on my 2008 edge towing the rp179. I only had to back up a few times but have not had to disconnect yet.
2008 Ford Edge
RP 179
