Page <123 |
![]() Posted: 15 May 2014 at 10:47am |
If the antenna is in the way, the dealer should be able to move it.
Hi WVGs,
My Fantastic Vent Ultra Breeze cover was pretty (too) close to the TV Antenna. It was just touching the cover, so I siliconed a piece of grommet material (anti-chafing) just so the metal wasn't rubbing on plastic. A rub-rail. Seems fine after 600 miles or so. ![]() ![]() |
West Virginia Girls ![]() Newbie ![]() ![]() Joined: 15 Sep 2013 Online Status: Offline Posts: 30 |
That's exactly the problem we have--just so close to antenna! Will show the dealer the photos & see what happens. Hate to move anything--more roof holes you know. Anyway, we appreciate your advice & the pictures! Thanks again!
Billie & Debbie
Furry friends: Jake & Mollie 2013 RPOD 177 2015 Toyota Tacoma TRD |
kymooses ![]() Senior Member ![]() ![]() Joined: 01 Aug 2010 Location: Louisville, Ky Online Status: Offline Posts: 1807 |
Let us know if that works out for you too Billie!
Thanks everyone......picked up our POD today at the dealer and they got the MaxAir II vent cover installed perfectly. He said there's not much room, but it did fit! Yippee! Also go the friction sway control added too. Froggie Pod is ready to roll!!!!!
Billie & Debbie
CyberShanks ![]() Newbie ![]() ![]() Joined: 25 May 2014 Location: Ackworth, IA Online Status: Offline Posts: 14 |
So, curious, does "All" of the Fantastic Fans have the moisture sensor? I don't see anything on it that says that it will auto-close??
Thanks, Jim |
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
There are different models of the Fantastic Fan, some have rain sensors, some don't. Of course to have the rain sensor it also requires the motor to open and close it...
As for the antenna- it does not require new holes in the roof if you are ok with it being angled some. There are two cross bolts in the base that can be removed, rotate the antenna until it clears whatever then drill new holes in the base and remount. This is of course assuming turning it will allow it to clear whatever. |
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
Page <123 |
