Plantguy
Calendar Event: Zamp Solar Posted: 02 Aug 2015 at 5:40pm |
I have a 2015. 179. It came with the Zamp port. Does it also come with a regulatir/controller? Seems like if the Pod comes setup for a Zamp solar panel pthere would be a regulator/controller built in to the system. If using a inverter are 2 6 volt batteries better than one 12 vwith a solar Charger? Also, anyone have an opinion on a flexible rooftop Panel?
Life is too important to be taken seriously!i
rumman
Posted: 01 Aug 2015 at 8:58pm |
I have a 2014 179 , dual 6V batteries and a 150 Watt solar panel permanently mounted on the roof with a charge controller and my display on the controller never goes below 12.0 volts. Have used them for a week running on just batteries with no problems. I also have a 2000 watt Yamaha generator just in case, have yet to use it with this trailer though. I couldn't be any happier with this setup. Works like a charm. Well worth the investment.
2014 RPod 179 towed by 2016 Chev Colorado (V6).
WillThrill
Posted: 01 Aug 2015 at 8:43pm |
Originally posted by MPRpod
In response to Topher 2u2 and his 100W Renogy setup:
I'm contemplating the same setup for a two week trip to the desert, but know little about electrical. What you describe seems simple enough but I want to make sure I'm understanding correctly since I don't have the Zamp connector on my 2014 177. It appears you use the alligator clips supplied with the panel to connect from the panel directly to the battery - is this correct? It also sounds like there's an in line fuse with the alligator clamps. What does the fuse protect if you're using the charge controller? You mention you charge phones with this setup and here's where I really demonstrate my ignorance: If you're running the Pod only off the 12V system, how are you watching TV or charging your phone? Do I need to buy an inverter of some type? I'll have a generator with me as a back up but want to minimize use and the amount of gas I need to carry. Thanks for any help, advice, or clarification!
The solar panel will need to run to a charge controller, which regulates the voltage and amperage going to your batteries and charges them correctly. So your solar panel will be wired to your charge controller, which will also be wired to your batteries. I show how to do this with lots of pictures in the thread I referenced earlier.
I have a 10 amp in-line fuse going from my charge controller to my batteries, though it isn't absolutely necessary. It's a safety measure so that if something screws up with your charge controller and/or solar panel, it won't fry your batteries.
You can indeed run your TV from your batteries, but you will likely need an inverter to do it unless your TV runs on 12v DC. You can either use alligator clamps to connect the inverter directly to your batteries, or you can wire your inverter into a spare opening in your Pod's fuse box. Be aware that a TV will probably draw at least 100 watts, maybe much more, and this will drain your batteries in a matter of hours. If you plan on watching a lot of TV while not running your generator, I would suggest looking at some of the small DC powered TVs out there. Some even have built in DVD players and only draw 5-10 watts.
To charge your phone, all you need is a 12v socket. These must also be installed into an opening in your fuse box. There are many pictures in this forum of people showing how to do this. It took me about 20 minutes. You can then use a car charge to charge up your phone.
2014 Hood River 177
2005 GMC Envoy XL
MPRpod
Posted: 01 Aug 2015 at 12:50pm |
ChinookPod
Posted: 29 Jul 2015 at 2:47pm |
We have a portable 80W Go Power panel, works great. However, this spring we installed a 100W Solarflex panel on the pod roof. We cannot store the pod at home so now the (dual) batteries are always charged, even after sitting in the storage place for several weeks. It has been a big simplification in our podding. We haven't yet had to plug in the portable panel, but may need it if we park in the shade, or when the daylight hours decrease.
2014 RP171 HRE
2010 F150
sailor323
Posted: 29 Jul 2015 at 2:33pm |
Price is not always a guarantee of quality.
Hayduke
Posted: 29 Jul 2015 at 12:48pm |
Originally posted by furpod
Zamp is not the least expensive.. doesn't make them a "ripoff" any more than a Mercedes is a ripoff. Can other cars get you from a to b for less money? yes. But that doesn't have jack to do with if you were ripped off or not buying it.
Again this is just my opinion: Yes a Mercedes costs more than a Hyundai of same size, and it is generally accepted that the Mercedes is a better quality product. In this solar panel scenario, I think you're paying Mercedes price for the Hyundai quality. I haven't seen anything to show that the zamp panels are any better than renogy.
2012 177 HRE
2017 Tacoma Double Cab
topher2u2
Posted: 28 Jul 2015 at 4:25pm |
I purchased the Renogy 100w Suitcase and it came with an SAE connector that will plug right into the port labeled a Zamp ready on the R-Pod. I chose to connect to the battery instead because the alligator extension has a built in fuse and when you pull the off the extension from the SAE connector, the fuse is no longer in-line. I guess I could wire a fuse into the cable, and still use the SAE port.
The 100w panel is plenty for our needs. We have run a the 12v fan (all day and night), watched TV, charged phones, and run lights with no concern of draining the battery.
#3PsnRPod
2016 R-Pod RP 171
2015 Jeep Grand Cherokee
WillThrill
Posted: 27 Jul 2015 at 11:01pm |
In the thread below, I show how I connected a 100 watt Renogy solar panel to the Zamp port. It's a simple process when you have the correct equipment, which I discuss.
If you are willing/able to make several adjustments to the solar panel throughout the day so that you get maximum direct sunlight, you can send about 30 amps (360 watt hours in 12 volt terms) to your batteries. This takes into account the inefficiencies of battery charging.
360 watt hours is enough to power a 30 watt device for 12 hours, for instance. Whether this is enough is dependent on what you're planning on running. This should be enough to keep your refrigerator's electrical panel going, allow for lighting in the evening, and let you run the Fantastic Fan for a bit as well. If you want more than that, you'll probably need multiple panels.
http://www.rpod-owners.com/forum_posts.asp?TID=5017&title=connecting-a-100-watt-solar-panel-to-zamp-port
2014 Hood River 177
2005 GMC Envoy XL
Robwid
Posted: 27 Jul 2015 at 10:32pm |
My wife and I do a lot of dry camping ( no hookups) so my dealer recommended 2 - 6 volt batteries. We're in our fourth summer and have never had an issue with the batteries running low. I finally used a multi meter to keep tabs on them this summer. On a recent 4 day trip the batteries measured 12.80 at the start and 12.46 the end. I looked long and hard at the Zamp panels and the gear head part of me wants them but the practical, cheap part of me says "why bother!"
Rob
2012 HRE 177
2010 Toyota Tacoma
