yellowstonestu
Topic: The great unveiling Posted: 30 Apr 2014 at 5:31pm |
How much weight does that add to the tongue?
I added a small wooden dual battery box and thinking of adding a generator to the tongue and was worried about the added weight. I think that you may have surpassed me there, therefore, I probably shouldn't worry about my added weight.
Looks great!!!!!
Yellowstonestu & Bela the Vizsla
2008 Toyota FJ
2015 RPod 179 (Pod #2)
Goose
Posted: 30 Apr 2014 at 5:35pm |
Very nice! It kind of has that Vibe look with a slanted nose. Goose
kymooses
Posted: 30 Apr 2014 at 7:39pm |
@Marwayne: Congratulations on the finished product. Truly is a sight to behold.
RPodWeGo
Posted: 30 Apr 2014 at 8:27pm |
With that front end my mother-in-law would be able to go with us and stay in her own place! Ha, ha, actually she is very nice.
RPodWeGo
RPod 177
04 v8 Toyota 4Runner
marwayne
Posted: 30 Apr 2014 at 9:09pm |
Looks great!!!!! |
As of now my tongue weight is 290 pounds, I like to get to about 350 to 400 pounds.
Seanl
Posted: 01 May 2014 at 7:36am |
Looks great!!!!! |
I put a 120 lbs genset and dual batteries on the tounge of my pod without issue.
Seanl
Posted: 01 May 2014 at 7:39am |
Originally posted by marwayne
The dolly I build myself. |
I don't think that marwayne has to many things on his pod that he did not build himself. If you notice his tagline. If you want something done right, do it yourself.
CasaJack
Posted: 01 May 2014 at 10:46am |
That's about the same tight fit I have too. Thanks!
Jackdaddy
bcskimiller
Posted: 01 May 2014 at 7:42pm |
marwayne, your nose job looks like an interesting addtion, def helps to solve the problem of having too much stuff! Quick question, I saw your drill sticking out of the tounge jack, how did you do the conversion? The only thing I have found so far is to cut off the handle and weld a head on that your drill will take, but I dont have ready access to a welder, so was hoping for a "quick fix"... Thanks! Bobby
Me, the Wife, 3 Kids 5 and under...its Crowded!
2014 RP-178 HRE
2017 Expedition EL 4WD
marwayne
Posted: 01 May 2014 at 11:16pm |
When I cut off the crank I left the nipple as long as I could cut a thread on it and put on a long nut.(don't know what they are called) I then filed a small section of the nipple flat and put a setscrew in to the nut. see pic.
