Page <12 |
![]() Posted: 22 Nov 2017 at 8:57pm |
Been using this one for 4 years. Never had a problem with TV or laptops.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
The Bestek 150W Power Inverter is the one I bought for use with the television. I have a larger one that I did not want to use for the television because of the larger power draw and the fan noise it makes when it is running. 150W is more than enough for the television plus it has dual USB charging ports which also can come in handy if you don't want to install a dedicated USB charging port alongside the 12V outlet you will need to install.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
That's a nice size, and I like the USB plugs. Two birds with one stone.
That's the size and type (pure sine wave) we put in our 179 and it has worked out well. I can even run the humidifier on my CPAP with it. |
Page <12 |
