Page 12> |
venkyle ![]() Newbie ![]() Joined: 27 Apr 2015 Location: QC Online Status: Offline Posts: 11 |
![]() Posted: 09 Jun 2016 at 6:58am |
Hello RPOD friends!
We recently put our trailer on a spot right o nthe water and went to set up our grey water hose that was sold with our trailer. It is a blue flexible hose and does not connect to the trailer side or fit into the septic hole....what do other people use? And where can i get it as I live in petawawa ON and they lack a store....
Can't Wait for Camping adventures!
kymooses ![]() Senior Member ![]() ![]() Joined: 01 Aug 2010 Location: Louisville, Ky Online Status: Offline Posts: 1807 |
The Rhino brand sewer hoses are very sturdy and good.
I bought mine online years ago and have had no issues with it.
Souns like you are missing the couplers on both ends.
yes! Thank you!
ron/roscoe ![]() Groupie ![]() ![]() Joined: 13 May 2016 Location: Hanahan, SC Online Status: Offline Posts: 84 |
Where do you store the hose going down the he road?
Ron Rowland
Camping world has a 64 inch hose carrier, capped at both ends for $37.00, I comes in black or white. I was going to look at fence posts, lowe's has 5 inch, seems way to big. Any suggestions?
Ron Rowland
The CW item will work. I prefer the SuperSlider unit:
http://www.dwincorp.com/products/125/NEW-SUPER-SLIDER-Adjustable-SUPER-TUBE It can be adjusted to exactly fit the mounting spot. Use the 43/80" version to ensure adequate overlap and install it crosswise under the trailer. |
I'll it match the two mounting bracket holes already on the Rpod 178? I was thinking about dis-guarding the short hose carrier already there.
Ron Rowland
Do the end caps move? I need the Mounting brackets to move to fit my existing holes. My hose is 60 inches. The tube at camping world end caps do not move.
Ron Rowland
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
the " fence post works perfectly for storing the sewer hose. I also bought end caps that fit the post. I mounted it directly to the pod frame with angle brackets. the end caps are attached with small bungee cords. I drilled several small drainage holes in the bottom of the pvc post before mounting it. I also mounted a plastic food storage box on the side to hold the flush fitting.
Vann ![]() ![]() |
Page 12> |
