Page 12> |
Daniel ![]() Newbie ![]() Joined: 20 Aug 2019 Online Status: Offline Posts: 3 |
![]() Posted: 28 Aug 2019 at 3:59pm |
Hello everybody my name is Dan I'm fairly new to the Forum. Just purchased a 2017 r-pod 178. The previous owner had modified the dinette table area. They put in a futon type bed. I have all the original cushions with no table. I'm simply trying to put it back to its original configuration. I'm not even sure if I can buy a new table for this camper. Any ideas would be helpful thank you so much
john in idaho ![]() Senior Member ![]() ![]() Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
You are not missing much. I have the foldup table that came with our 2015 179 in the green house as a plant stand.It was always in the way, heavy, and hard to sit at. I made another one we like a whole lot better. 3/4" plywood 2 ft square for the base, a boat store pedestal socket , pedestal and a similar socket mounted on a 3/4" ply on the underside of the plywood top, which is about 6 or so inches bigger than the bottom. It rides on the bed all apart. If you live close to Idaho you could get this one out of the greenhouse. Hardly used.
podwerkz ![]() Senior Member ![]() ![]() Joined: 11 Mar 2019 Location: Texas Online Status: Offline Posts: 966 |
Yeah the original folding table is heavy...really heavy. It will pinch your fingers badly if you actually try to fold it. And the legs were always in the way when you made an attempt to sit near it... AND on top of all that, the straps that came with it were intended for tying it down during travel...what a pain.
You are much better off to buy a standard pedestal base and buy or make a suitable table top surface.
Happy Tripping ![]() Senior Member ![]() ![]() Joined: 27 May 2014 Online Status: Offline Posts: 473 |
I sorta like our table. Keep it out of the rain tho or you'll need a new top.
Internet search results from 2010 - It probably isn't current but gets you started. Scott, Yes, the new table base is available for your purchase. I do believe you can use your current table top. The base is $85.50 plus shipping. You may order through my parts administrator Brandie Lamb at 574-642-3119 Ext 209. We accept Visa or Master Card. Sincerely, Susan Thornberg Warranty, Parts & Service Manager |
OK thanks for the info. I'll probably work on making my own table and a different type of Base. I'm pretty tall and I was also wondering about legroom.
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
We had the same bulky, terrible table in our 179. I built a new table with double pedestals from 3/4" birch plywood top and also a plywood base. It travels on the bed after taking the pedestals apart. I made it larger than we wanted originally and have gradually cut it down to the size that we want(24x39). It is very stable and much lighter than the original. Vann
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6435 |
I like the wood-grain of your table. Is it some sort of plywood to minimize warping? If so, how did you finish off the raw edges?
Ben Herman ![]() Senior Member ![]() Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 359 |
Looks to me like standard birch plywood. All big box stores carry it in 4x8 sheets. If you have a lumberyard near you, an even better option is baltic birch plywood. Usually comes in 5x5 sheets. Baltic birch is better quality plywood than the standard stuff sold by Home Depot/Lowes. You can get the edges nice and smooth, then 3 coats of poly and you'd be all set. Nice job btw Vann!
Woodmiester ![]() Senior Member ![]() ![]() Joined: 03 Aug 2018 Location: Greenwood IN Online Status: Offline Posts: 142 |
The very first thing we did was to replace that stupid table with a home built. Man, that thing hurt coming down on your fingers!!!!!
A suggestion.......If you build one, put a table ware drawer on it. (One more drawer freed up)
Swampfox
Ben Herman is correct-it is 3/4" Birch veneer plywood. I finished it with Tabletop Varnish from Woodworker's supply. It is a very hard and durable finish. I used 4 coats with steel wool between coats. It has been very serviceable for us and can be easily repaired if it does get scratched. Sand the edges carefully and apply the same finish as the top -there are no rough edges or splintering. I used standard 3/4" B/C grade plywood for the base. It is cut to fit tight between the ottomans and has some velcro glued to the floor and the underside of the base-it is rock solid. the pedestal base and top are screwed to the plywood top and base with 1"x#12 screws. Vann
Page 12> |
