  New Posts New Posts RSS Feed: 2017 rpod 179
Topic Closed2017 rpod 179 - Event Date: 28 Aug 2017 - 10 Sep 2017
Direct Link To This Post Calendar Event: 2017 rpod 179
    Posted: 28 Aug 2017 at 7:09pm
Originally posted by condensed
We have a new 2017 rpod 179 that we pull with a GMC Sierra 1500 5.3 v8. The trailer is constantly fishtailing 4 to 5 inches with any wind or uneven road conditions. It is not heavily loaded when we travel. Has anyone experienced this condition and found a remedy for it ?
Thanks for any ideas
ohardy
You have some sort of rigging problem. You really shouldn't see any issues like that with that TV. It should easily handle up to 500# tongue weight, and not really need anti-sway or WDH.
That said, you may have the weight distributed incorrectly or some other thing. I would first weigh the R-pod, and the tongue weight and make sure you're within normal limits.
The R-179 should weigh between 2,800 and 3,800 pounds, with "about" 10% (280-380 lbs) on the tongue. Depending on how the rig is loaded, the tongue weight could be as much as 15% (420-570 lbs). So to rule of thumb it, expect ~~ 300-550 lbs on the tongue. If you're outside of that zone, then you may just need to move things around. If you're inside that zone, then you might very well consider a WDH, or anti-sway, or both.
We pull our R-179 with a Fastway E2 WDH which provides mild anti-sway in addition to the weight distribution, and we see zero sway or fishtailing. The F-150 and the R-179 go down the road as a "unit". No excitement.
Direct Link To This Post Posted: 28 Aug 2017 at 4:14pm
A sway bar would help immensely, that is all I use. I do not have a WDH, not with a 1500 chevy and a Pod.
mjlrpod View Drop Down
Direct Link To This Post Posted: 28 Aug 2017 at 3:57pm
I cant help, my 172 totally stays put behind me, ive never seen it move even an inch. I dont have anywhere near the T.V. you have, i tow with a Nissan Frontier 6 cyl, but i do use WDH. That might be the difference, also, i have carlisle radial tires and make sure they are at 65 p.s.i. frequently.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
ronahue View Drop Down
Direct Link To This Post Posted: 28 Aug 2017 at 1:51pm
Try filling your fresh water tank, the 179 trailers better with a full fresh water tank.
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
Direct Link To This Post Posted: 28 Aug 2017 at 1:03pm
+1. Good tips!
analogtime View Drop Down
Direct Link To This Post Posted: 28 Aug 2017 at 12:57pm
Are you using Weight Distributing Bars and Sway bars? They make a world of difference. Also make sure that any weight you ARE carrying in the POD is in the front end near the hitch. Check your tires. Low air will do this. And - of course - don't speed.
condensed View Drop Down
Direct Link To This Post Posted: 28 Aug 2017 at 12:51pm
ohardy
ohardyIII
