clickscrazy
Topic: Quick Convec Micro Question Posted: 26 Aug 2017 at 10:00am |
It has to be the microwave or something right behind it. When you open the door, it gets louder. Dealer is ordering a new one.
2018 R-Pod 171
2014 VW Touareg TDI
podenvy
Posted: 24 Aug 2017 at 10:10pm |
If you're absolutely sure it's coming from the microwave, then replace the microwave.
The fan in the electric panel turns on once you plug into shore power and it's to cool the converter.
2013 FJ Cruiser + 2015 rpod 179 HRE
clickscrazy
Posted: 18 Aug 2017 at 7:05am |
Yep. Will do. Just a pain. We have a trip scheduled in a few weeks. Hopefully it will still work.
Posted: 17 Aug 2017 at 11:10am |
Originally posted by clickscrazy
Brand new. We used MW once, it did seem to work. |
Warranty.. it's exactly why you bought new..
clickscrazy
Posted: 16 Aug 2017 at 9:47pm |
Posted: 16 Aug 2017 at 4:52pm |
I believe you are referring to the inverter? I am talking about the convection oven.
I just spoke with Forest River, they said it should not be making any noise.
They said it could be "Dirty Power", which is possible, since I am hooked up to a 15a circuit right now. (even though nothing is running) |
If you are talking to me.. No, I am talking about the MW. It has a cooling fan that kicks on when baking, or even nuking if it gets hot enough in the enclosure. It should make no sounds when not in use, or not having just been used. Have you used it at all? Is this a new Pod? or new to you? And "dirty power" has nothing to do with the amperage. If it was a dirty power issue of any type, it would manifest itself while being used. Not when off.
Posted: 16 Aug 2017 at 3:35pm |
A 15 amp connection is no more dirty or clean than a 20 or 30 amp connection. If your microwave is making a noise, it could be dirty power, or it could be something else. The 15 amp connection should be irrelevant.
clickscrazy
Posted: 16 Aug 2017 at 3:30pm |
Posted: 16 Aug 2017 at 3:15pm |
clickscrazy
Posted: 16 Aug 2017 at 1:28pm |
I wonder if it is running because it is so hot in the unit itself (AC OFF IN FLORIDA).
