Page <1234> |
![]() Posted: 22 Jul 2017 at 5:47pm |
+1 , I have a Craftsman DC clamp om ammeter and multimeter. Works fine.
twodues ![]() Newbie ![]() ![]() Joined: 31 Oct 2016 Location: Michigan Online Status: Offline Posts: 20 |
Current drain is 7amps at the battery. No current measured at each individual 12v circuit. Bad controller?
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
Try pulling the two high current battery reversal fuses. This will disconnect the converter from the battery and power panel. If removing these fuses does not interrupt the drain look to the slide mechanism or the power tongue jack if you have one. These devices don't go through the fuse panel.
Just for grins I would make sure your ebrake circuit is still in place and pin hasn't been pulled, that ebrake works off the battery.
ToolmanJohn ![]() Senior Member ![]() Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
mcarter +1 good call!!! twodues you should check it out.
I was thinking of some kind of ground fault, with a screw having been put through one of the positive supply wires, because the propane detector (hard wired) takes a week or more to kill a 12 volt. But the idea that the breakaway switch is somehow responsible is a good idea.
I got busted on that break-away switch once. Guess I inadvertently pulled it disconnecting TT.
Experience can be a harsh teacher.
I would also go with pulling fuses one at a time and seeing if the drain is on one of the circuits. The brake cable is something I would not have thought of but it makes sense. Also, check the TV antenna booster. That is an easy one to miss. Make sure it is off. |
Seven Amps is in the ballpark for two brake magnets and they do not go through the fuse panel. If the emergency brake pin is pulled or the switch is defective you can see this much drain BUT you will certainly know something is amiss when you try to move the Pod. |
All logical suggestions. I've tried them to no avail before posting the initial thread.
Page <1234> |
