  New Posts New Posts RSS Feed: Water Heater Problem
Topic ClosedWater Heater Problem
Hayduke View Drop Down
Direct Link To This Post Topic: Water Heater Problem
    Posted: 25 Jun 2017 at 9:50pm
Our water heater stopped functioning in the electric mode last year. We share the rpod with a few family members, and from asking other users I came to the assumption that the electric element had been burned out.
We had the pod in at the local rv repair place for a few other things (not an rpod dealer, but they do sell other forest river brands/models). We asked them to fix the water heater. When we picked up the trailer, the service people said the water heater element was drawing the expected amount of amps (I forget the exact number) and should function fine.
This is our first time using the water heater since, and still no heat on electric. The breaker inside and the switch outside are both on.
Any ideas? How can I go about diagnosing? Is the statement about it drawing the right amount of power accurate?
2012 177 HRE
2017 Tacoma Double Cab
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 26 Jun 2017 at 7:24am
Electric is a little slower than propane I think.  Have you left in on overnight and still no hot water?  Does it work on propane?  And where I"m going with that: are you sure the bypass valves are set correctly?
Direct Link To This Post Posted: 26 Jun 2017 at 9:34am
Ditto on the bypass valves.
Direct Link To This Post Posted: 26 Jun 2017 at 10:59am
Works great on propane. Left it on electric for several hours last night with no result.
Bypass valves are all in the correct orientation.
2012 177 HRE
Direct Link To This Post Posted: 26 Jun 2017 at 4:47pm
Check the water heater element for continuity. It's an element. Just like your oven at home. I think that's your problem.
Direct Link To This Post Posted: 26 Jun 2017 at 6:58pm
Direct Link To This Post Posted: 26 Jun 2017 at 7:06pm
I get hot water in 15 minutes on electric. That's because my element is working. Replace the electric element.
CharlieM View Drop Down
Direct Link To This Post Posted: 26 Jun 2017 at 7:23pm
Make sure the breakers are on and the outside switch on the WH is on. The WH electric element is approx. 1500 watts. If you have any way to measure the input current to the trailer you should see 10-14 Amps. If you get hot water on gas the bypass valves are set properly.From a cold start you should get some hot water in 15 minutes on electric.
Direct Link To This Post Posted: 26 Jun 2017 at 7:26pm
Yep, that's what I said.
Direct Link To This Post Posted: 27 Jun 2017 at 12:28am
Thanks for the input so far. Let me summarize:
1. I'm positive the bypass valves are correct. I get hot water in a few minutes on propane.
2. The switch on the exterior of the water heater and the breaker in the converter panel are both on.
3. The rv service center states they tested the electric as pulling ~10 amps.
I still do not get hot water on electric.
2012 177 HRE
